Dirty 30
04-22-2012, 12:47 AM
I posted this in the TBSSOwners forum but the guys there don't seem to be much help. According to them, there is no way that one can make it work without buying the $1,000 4L80E Conversion Kit :swing: :eyes:
http://www.tbssowners.com/forums/showthread.php?t=78163
For those of you that made your own 4L80e swap, which TCM File is needed to be able to run the 4L80e with a 2007 TBSS? The 4L80e is already installed in the TBSS, I am just needing something to get the it driving. I have HPTuners and have access to EFIlive.
Any help is appreciated,
Thanks
I did receive help from one person and managed to get the TBSS running. Here is the latest update...
Ok, we got the TBSS running but have encountered some problems.
To start, I don't own the TBSS, it belongs to another member. The work was done by LSX Motorsports in Mansfield, TX. I don't know the shop owner very well but the few times I have met him, he has been a straight forward type of guy. They did a good installing the bracket on the crossmember for the trans. They've done 4L80e swaps on GM Trucks without problems but this was their first TBSS. As far as the wiring goes, he says he switched pin t and pin s for the tcc lockup and wired the factory speed sensor wires to the front speed sensor on the transmission.
We put in 4L80e file that allowed it to shift and run properly from the shop to my house. This file (File 1) was created using EFIlive and then read with HPTuners Beta, before Dru posted the link. We noticed that the shift indicator on the gauge cluster was stuck on "1st", even though the transmission shifted normal. I also noticed that the MPH in the HPTuners Scanner was displaying Zero all the time. But the main concern is that the scanner is also showing a U100 loss of ECM communication, U101 loss of TCM communication, and another Uxxx loss of BCM. There was also a MAPS code and an O2 Bank 1 Sensor 1 code, but that could be related to the cam swap with the ECM tune.
The tune that Dru showed us was for an '08 TBSS but I managed to flash the TCM tune together with the '07 TBSS ECM tune It's a different calibration and the tune is a little different but not by much. Still drives fine with that one but the codes, speedo, and gear indicator are still problematic.
Attached are both files, remember these were opened with Beta.
So far both work for us as far as shifting and driving goes.
EDIT: For some reason, I couldn't attach the tunes. I can send it via email if anyone wants to look at it.
I'd like to know if anyone has a solution for this. I think it may be in the wiring. :confused:
Thanks
