LS4 Performance - slightly dissappointing day at track
SSWHITE07
04-22-2012, 01:16 AM
I ran my impss the other day at the drag strip and only got a best of 14.72@95mph. It did hook up on that run and it was hot. Now the next 2 runs the traction control/anti score kicked on even though tc was off. Is there a certain way to race these cars? It really sucked that i couldnt get a fair run out of this car. Any suggestions?
BlackImpSS
04-22-2012, 08:20 AM
What were your 60 ft times? Your trap seems a little low, and most people suggest keeping it in 2nd otherwise it shifts into 3rd which causes slower times and trap speeds. But otherwise it's just finding that sweet spot with little to no wheel spin.
SSWHITE07
04-22-2012, 10:12 AM
Best 60 ft was 2.2 on the best run. Then i was getting 2.5s because the anti score thing
Dom87SS
04-22-2012, 12:09 PM
2.2 is not "hooking up". The first pass I made I went like 14.8x@96 with a 2.58 60'. A couple passes later running it out in 2nd and netting a 2.08 60' put the car in the 14.0's @ 98 and some change. For every tenth you drop in the 60' is about 2 tenths out the back.
SSWHITE07
04-22-2012, 01:13 PM
I just couldnt take off without the car cutting power off.
Sadden
04-22-2012, 04:17 PM
Quit mashing the loud pedal so early.
BlackImpSS
04-22-2012, 08:47 PM
Yeah you want to basically be giving just enough gas to where it doesn't or barely spins at all until you hit the mph where it doesn't spin at all you should be floored.
DomSS-what track do you go too?
Dom87SS
04-22-2012, 08:55 PM
GLD in union grove usually, occasionally venture out to Byron or Cordova. GLD is about an hour, Byron is about a hour 45, Cordova is about 2.5 hours.
BlackImpSS
04-22-2012, 09:10 PM
Gotcha I'm about 1.5 hours from Cordova and Byron. I've only been to Cordova once and I really didn't like the track at all. Been to Byron a few times over the years, and will be heading back to see what the Imp will run. I'm a big fan of the track, and how laid back all the workers are there.
Dom87SS
04-23-2012, 01:14 PM
i dont race much out there, i mainly shoot pics for different events out there. GLD is my home track i spend the most time at.
BlackImpSS
04-23-2012, 02:04 PM
Yeah that makes sense. I wouldnt want to travel farther than I had too, just in case you ended up breaking something.
94ss06gxp
04-23-2012, 04:19 PM
I got my gf's gxp down to a 1.9 60ft, you just have to find the sweet spot. . .
Panther427
04-23-2012, 10:15 PM
Better than my best of 15.1
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
