Pontiac Firebird 1967-2002 - Adding an overflow resevoir on a 67 Firebird...there isnt one
mrrman
04-22-2012, 01:25 PM
Has anyone added an overflow resevoir for the rad on a 67 Firebird. Seems odd that there isnt one in place. If you did can you tell me what capacity jug you used and where did you mount it. Thanks
mrrman
04-23-2012, 08:12 AM
Found one
JohnnyBs98WS6Rag
04-23-2012, 12:14 PM
'67s probably didn't have one from the factory. I don't remember seeing them until the early '70s.
tuske427
04-23-2012, 11:07 PM
you can add it on the front side of the core support if you want. I've added aftermarket tanks there. however, I recommend painting it flat black so it's not obviously visible through the grille.
older cars typically didn't have them, they just had an overflow hose dump them on the ground.
