Which wideband with HP Tuners pro
I'm looking for a wideband that I can mount in my a pillar gauge pod but can also plug into my hp tuners pro. Is there one that is that much better than the other? I was looking at the AEM but wanted to get opinions before I pulled the trigger.
I'm in the same boat. I dont necessarily need data logging abilities, but my Autometer wideband sucks ***. Dont get one of those. I think from what I'm reading, the AEM is the best, and its fairly low cost.
I use the AFX to tune with but i have a dynojet gauge/sensor permanently mounted in my car. dynojet makes an adapter harness that allows you to use the gauge AND scan/log at the same time. i don't have that harness, but i know they make it and its relatively inexpensive.
I have LM2. So far I wish I had ordered something else. You supposedly have to run a chassis ground to get a smooth signal but I have not has a chance to try it so I am getting a jagged line on my graph. Also wish I could find one without all the stuff I don't need like OBD2 scan capabilities and a dozen I.O.s I already have with HPT pro.
I have had my AEM for over a year and have had no issues with it. I have had pretty good luck with it I guess. Can you provide hard data on why you thing the AEM wideband is Junk. This could help myself along with others that will be purchasing widebands in the futures.
A customer had an AEM he had just installed in his car and I insisted on using mine since I knew the previous results with the AEM on my personal setup, same deal with his!
Fast forward to a couple years back when I converted to the NGK AFX I did a back to back WOT pull with both widebands installed and the LM-1 was reading 12.9-13.0 like I had tuned the car to. The NGK was reading 11.9-12.0 telling me the Innovate LM-1 was a full point off at WOT. Sure that's safe however not what I'm looking for when I want to make power. Retuned the car with the NGK and picked up 2-3mph at the track!
From a tuner standpoint the NGK is hands down the best and most accurate wideband of any mentioned in this thread PERIOD!
There is one other alternative wideband I would consider as well, the Haltech Dual Channel wideband. I used one of those in my 403 setup in my Sig and also did some comparing with my NGK tuning wideband and they read identical readings between them. The plus side to the Haltech is it's capable of running 2 widebands and has an analog output for each one. There is also round gauges available for it as well. Only drawback is currently it only supports Bosch sensor's. NGK supports Bosch and NTK senors! I personally use NTK sensor's for tuning customer car's with.
FWIW, Ed Hutchins (edcmat-l1) recommended the NGK to me when I asked him what wideband he preferred.
If you hit up the HPtuner forum on their website you will see that alot of people that do the tuning on their own rides as well as some tuners that tune for shops stand by the NGK as well.
You will also see Greg Banish talk about the NGK wideband as well. ECM the company that makes the Lambda Pro is the same company that designed the NGK wideband. We are looking to upgrade our shops wideband to a Lambda Pro here pretty soon just to have that added accuracy for tuning. In the end the quality of the tune can only be as good as your interpretation of your gauges and data they present. IMO I would want the most accurate of the bunch!
