Wheels & Tires - 15x10 drag wheels without grinding?
2 Stroke Racer
04-22-2012, 08:51 PM
Are there any 15" rims that will fit my fourth gen without grinding caliper.
Even minimal grinding is fine. Or what 16" rims would anyone recommend? I have 15x3.5 prostar weld's for the front. So anything that will look similar.
I would do the 16's because I already have 16" slicks. Any suggestions welcome. Thanks.
projectX
04-22-2012, 09:03 PM
Racestars - no grinding. (cheap too) IMO
BOBS99SS
04-22-2012, 09:05 PM
Look at the thread about 7 down from yours, someone just asked about this yesterday, you want wheels that you wont have to grind its going to cost alot more,
2 Stroke Racer
04-22-2012, 10:04 PM
I'm not totally against grinding. Im just wondering if there were 15" Wheels I don't have to grind. Do you not have to grind the racestars? What backspacing? Thanks for the replies..:usa:
heymoej
04-22-2012, 10:07 PM
bogarts.......
Z28/2002
04-22-2012, 10:25 PM
Weld RTS
Mr. Trick
04-22-2012, 10:36 PM
F-body specific bs street lites. Bogarts are sick though if you have the funds.
projectX
04-22-2012, 10:52 PM
No grinding - They make 15,16,17 and for B.S 5.5,7.5, etc - around 175 ea
2 Stroke Racer
04-23-2012, 04:37 PM
Really? 15"x10 with 7.5" backspace would be what I would need then correct??
Where did you find them for $175??
projectX
04-23-2012, 07:08 PM
Ask and you shall receive: http://www.racestarindustries.com/
Also, yes 15x10 7.5bs for our cars.
2 Stroke Racer
04-24-2012, 10:59 PM
How much grinding on a 15x10 with 5.5 b.s.??
There weld prostars. Thanks.
Z28/2002
04-25-2012, 10:53 AM
How much is your rearend narrowed?
black and pink z28
04-25-2012, 11:53 AM
my buddy has racestars and he had to grind a little on the cooling fines
2 Stroke Racer
04-25-2012, 12:08 PM
None yet. In the process of ordering strange s60 but wasn't planning on shortening.
black and pink z28
04-25-2012, 08:16 PM
a 15x10 with 5.5 b.s will stick out of the quarter panels pretty hard
Camaro396
04-25-2012, 08:57 PM
Weld Racings RTS wheels fit without grinding.
mterveen
04-25-2012, 11:49 PM
should be "may" fit without grinding. mine and many others have had to grind "a little" to make them fit. no big deal tho.
Z28/2002
04-26-2012, 10:39 AM
This is what I was getting at, if it isn't narrowed then you'll need 7.5" of backspacing on a 15x10 for a stock length rearend
2 Stroke Racer
04-26-2012, 12:36 PM
Gotcha, so what would my benefits of shortening my reared be?
Other than making a 5.5 bs work..
BOBS99SS
04-26-2012, 02:57 PM
You can have a really cool killer lip on the rim lol,honest thats the only benefit you will prob see on a h/c ls car
xDIRTYx
04-26-2012, 07:41 PM
Shorter axle's are stonger axle's, same goes for the housing. It will be a bit lighter also. If you can shorten, you might as well
