Generation III External Engine - Motor mount bolt size
View Full Version : Motor mount bolt size
bigantws6
04-22-2012, 11:23 PM
I been searching for the motor mount bolt but the only one I find is the one that goes into the block I need the one that goes threw the motor mount
dr_whigham
04-23-2012, 07:05 AM
This is prob no help, but I do know they are 18mm bolts. I don't think length matters, as long as they protrude PAST the clamshell. width is a different story, and I haven't been able to find that answer either.
http://i150.photobucket.com/albums/s98/Pocket_004/Misc/Bolts.png
Engine Mount Stud-to-Engine Block - 37 lb ft
Engine Mount Through Bolts - 70 lb ft
Engine Mount Through Bolt Nuts - 59 lb ft
Engine Mount-to-Engine Block Bolts - 37 lb ft
bigantws6
04-23-2012, 07:26 AM
Yea me either maybe ill call the dealership see I'f they know the size and if they do ill let u know
bigantws6
04-23-2012, 07:28 AM
See I lost the dam nut that goes on it and my dumb azz put the bolt in already so if the dealer doesn't know ima pull one out and go find one at lowes
bigantws6
04-23-2012, 05:25 PM
The bolt size is 12x1.75x160
