231/237 and a 2.04 intake valve. P/V?
Originally Posted by goinbroke
Will this clear? Has anyone run the tsp 231/237 cam with a 2.04 intake valve and cleared? Heads are 5.3 and unmilled.
LS1Tech Premium Sponsor
It will clear no problem with a 2.04 valve
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Just make sure you check it during install regardless. You can always end up with one of the engines that has a higher piston protrusion than normal. I don't know how much clearance that cam usually has.
