Forced Induction - Callie comprstars and gm crank
Ls sn95
04-23-2012, 09:57 AM
How much power can the calories comparative h beam rods and gm crank hold on and F1r looking to go about 1100 can these take that kind of abuse
dschmittie1
04-23-2012, 09:59 AM
Callies rates there H beam for 750 I think. I beam compstars have been known good to around 1100 rwhp. I have a set of I beam compstars in mine
hellbents10
04-23-2012, 10:00 AM
I would upgrade to a Callies ultra rod and a Magnum crank to make a real 1100hp on a blower car.
Ls sn95
04-23-2012, 10:16 AM
That's kind of what I expected any of you guys had any experience with Howard's billet I beam rods
68 SS
04-23-2012, 08:39 PM
I am running the Callie's ultra billet I beams on a magnmum crank, I would not attempt it with the cheaper H beams especially if you plan on turning it up and high RPM.
bad6as
05-02-2012, 08:02 PM
if your going to run that f1 to that power level you should look in to a aftermarket crank. turbo cars can get away with more power from the stock crank then a procharger
tirefryin_s10
05-03-2012, 01:01 PM
I agree with most of the opinions expressed if it were a turbo car things would be different I made north of 1100 rwhp through an unlocked auto with the callies H beams and a stock crank but I also did bend one at less power.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
