Carbureted LSX forum - LS Combo
LAYNRBR
04-23-2012, 11:53 AM
I'm new to the LS Motors and would like to do the swap over in my 73 Nova. What is the best motor to start with? I would like my 3300lb car to run in the 9.70 range and possibly spray it to the 8's and drive it on the street?? I want to stay carbureted. What is the best LS motor/combo to acheive this?
Doug G
04-23-2012, 04:01 PM
More cubes = more HP/TQ....but smaller LS motors have done it.
http://ls1tech.com/forums/drag-racing-results/1290877-fastest-all-time-n-any-cu.html
Edit:
more for your reading pleasure....
http://www.ls1tech.com/forums/drag-r...ck-ci-h-c.html
http://www.ls1tech.com/forums/drag-r...s-engines.html
http://www.ls1tech.com/forums/drag-r...1-74-bump.html
http://www.ls1tech.com/forums/drag-r...s-any-c-i.html
http://www.ls1tech.com/forums/manual...peed-list.html
http://www.ls1tech.com/forums/nitrou...fast-list.html
http://www.ls1tech.com/forums/nitrou...rous-cars.html
ZONES89RS
04-23-2012, 09:31 PM
9s at 3300=big cubes all motor, as above links will show.
LAYNRBR
04-24-2012, 11:16 AM
Can't seem to get any of the links to work? I was considering the LY6 as a starting point? Possibly stroke it?
crossbreed383
04-24-2012, 03:17 PM
A well built 408/416 at that weight will run hi nines and not be anything special in terms of build
Id say keep it right at 12-1
mid 250int -260 ex lobe 670 lift comp huc lobe
TFS 245 cathedral port head w opt nos exhaust port
supervici ntake w 1000hp carb
good 3 speed with correct converter and 4.10 gear
That should run nines(9.80-9.65) on motor pretty easily and would prob need to be sprayed about 225-250hp to run about a sec quicker
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
