Nitrous Oxide - could i hit tens on a 200 shot with bolt ons and stall?
LeanPocket
04-23-2012, 01:36 PM
Ok, this is what i was thinking.
I ran a 12.0 @ 120 w/ a 2.0 60'.. through 2 gears on a 150 wet shot window switch. My 3rd gear wasn't catching on my stock 4l60e (stock stall) untill the trap zone.
So i was thinking,
upgrading to kooks 1 7/8 headers and tsp true duals today, order my stand alone unit from nitrous outlet to run c-16, build my stock 4l60e tranny, and put in a twin disk nitrous stall from circleD, re-tune for a 200 wet shot , and a nice drag pack to lower my 60' .. maybe upgrade my injectors.. and im thinking i should hit 10's.. or low 11's
I'm sure with the stall i should hit a 12.0 on motor, i ran a 12.78 on motor through a stock stall and hurt tranny
what do u all think, thx
sweet99ss
04-23-2012, 03:25 PM
I would figure out why your running so slow first. I run 12.3@110 with bolt-ons and stall. If you have a stall you sould be down in the 1.7-1.8 60ft range with a decent dr. Get a mt or tire that will hook damn good and you should be able to get a 1.7 60ft and than spray through the end of first.
SCott5
04-23-2012, 03:58 PM
I run 11.1s on a 125 shot dry with a 3600 stall on et radials
LeanPocket
04-23-2012, 04:16 PM
i ran a 12.78 through a stock stall, with my zr1 wheels and 315 mt et street 2's
I have a window switch, I tend to flip the switch when I feel the car hook.. instead out of the hole.. and with a stall it should be dirty out of the hole.
I'm torn on what wheels to buy so im stick my my DD setup for now...
sweet99ss
04-23-2012, 05:27 PM
I would figure out how to get the most out of the 150 shot before uping to a 200
BOBS99SS
04-23-2012, 07:34 PM
I would work on getting a lil better before throwing more juice at it, whats your suspension/rear/tire setup,if its in your sig my bad im on my phone
SCott5
04-23-2012, 08:17 PM
I would start with the known problems you have. Fix the tranny first and put a stall in it and then go back and try again. Then find some 16s or 15in drag wheels and put some sticky tire on it with more sidewall. Work your setup some more till you got all bugs worked out then if its not where you want, start shooting bigger
LeanPocket
04-24-2012, 08:35 AM
nothing else really bolt on wise, aside from what i mentioned above. Well i need a 9" and a nice DS.. but it hasnt broken yet lol
i got full bolt on suspension.. sig is not up to date.. stock shocks tho :/. My technique is down, and multiple 'street' passes.. unfortunately where i live, 10's are the new 11's so i have to keep up with everyone else. I'm considering a progressive controller
Tranny is being built, thats the main thing, and while its out I might aswell put the stall/cooler. Wheels and tires are in the budget, I'm just undecided on what wheels to buy. I'm not going to focus on motor runs, my car is more built/tuned towards nitrous right now. It will stay on a 150 with my stand alone, then get retuned for the next trip to the track for a before/after
sweet99ss
04-24-2012, 10:11 AM
Well i would say your set to go for 10's with the 150 shot. You should not need 200 shot to get 10's with full bolt-ons, stall, traction and 150 shot
01SOMZ28
04-24-2012, 02:49 PM
http://www.youtube.com/watch?v=2xNVmKTQIdE&feature=g-hist&context=G29a6f0eAHT5awogAKAA
LeanPocket
04-24-2012, 04:00 PM
exactly what iw as looking for thx :judge:
SCott5
04-24-2012, 07:31 PM
agreed
SCott5
04-24-2012, 07:35 PM
http://www.youtube.com/watch?v=6z7kDkGb-PM
This is my 11.19 run in my ta with a 125 shot.
LeanPocket
04-25-2012, 08:40 AM
well.. what kind of traps/et's would a 200 shot expect
2fresh
04-25-2012, 09:32 AM
my buddy did it with a 200 with a progressive controller/separate fuel kit spraying off the line on 28" slicks stock stall but the trans died the next pass full bolt ons and a hot cam and basic suspension.
LeanPocket
04-25-2012, 03:01 PM
Sweet, I might need to get that progressive controller. This is gonna be a terror on the streets lol
Pete91
04-25-2012, 06:45 PM
How much does your car weigh with you in it? Fix your tranny and do a stall. I don't think you will have issues running 10's. I was planning on running high 10's when my car was bolt ons with only a 100 shot. I did the heads and cam before I could find out though. A higher stall speed converter makes a world of difference.
SCott5
04-25-2012, 07:29 PM
My plan is 10.4s on a 125-150 shot with a bone stock ls1 with just bolt-ons including staying with my ls1 intake as well. So I think if you get your problems with your tranny figured out and add a stall you will be happy with the results
NVUSZ28
04-25-2012, 08:12 PM
Why'd you take out the 3600 stall that was in it?
sweet99ss
04-25-2012, 08:48 PM
Ill be extremely happy to hit 10's on the 100 shot. I am getin a refill tommarow and going to the track friday. Rasing the car up tonight to get it ready for the track so I can hopefully get atleast 1.7 60ft.
vbls
04-26-2012, 06:54 AM
im running 11.2 with a stock stall, 150 shot, just replaced intake with a fast. trying for 10's next
Brandon331
04-26-2012, 08:32 AM
its possible with a 150 shot we got my buddys car to run 10.88s on a 150 shot he had 3:73 gear, lid,headers, 3500 stall, worn out 275 mt drag radials, 150k miles on the motor, trans was going out. tapping the limiter in third.., ported tb, alot off tuning, stock suspenion..his car runs lower times on motor than you like 12.3's
SCott5
04-26-2012, 08:41 AM
I do 1.5 60' on a 75 shot and on my 125 shot i do 1.6s cuz it spins alil
LeanPocket
04-26-2012, 09:21 AM
because I need a nitrous stall, with a big shot like that it'll blow right through the converter.. or atleast, so i was told. I need something with anti balooning plates, and those plates have been associated with nitrous for a while now. They are used to reinforce the stock parts, to keep them from flexing from the higher rpm and power. I've seen cracked converters before.. so better safe than sorry.
I wasn't happy with my old one anyways, always wanted a twin disk circleD..
LeanPocket
04-26-2012, 09:24 AM
Do you all think i should slap on my 42lb injectors (ls3 style) for my 200 shot? I'm on my 28.8's right now with no problems on my 150 shot.
LeanPocket
04-26-2012, 09:31 AM
it weighed in about 3400'ish without me in it, i weight exactly 200
