View Full Version : 4.10 Gear 6 Speed LT1
Chanson
04-23-2012, 04:18 PM
ok so im 17 got myself a 95 WS6 recently and it has the 4:10 gears amd 6 speed and you know us teenagers "need for speed" but it seems to have very little power in 1st? very hard to peel out nd break loose? any ideas or tips to get mow low end power? thanks
BALLSS
04-23-2012, 06:55 PM
well if your WS6 does have 4:10's and a T56 you should be able to absolutely boil the tires in 1st-2nd, lay stripe in 3rd and bark the tires in 4th
....so if you can't something is killing power to allow this or your clutch is toast.
even stock motor and gears..you should be able to lite up the tires in 1st no problem
Chanson
04-23-2012, 09:50 PM
ya i'm guessing it is the clutch cause a buddy of mine with just a formula can roast em no problem but ya i can break loose in 2nd not 1st
Martin@Tick
04-24-2012, 09:48 AM
REV REV REV... Then dump clutch = :burn:
Disclaimer: Be prepared to break something ;)
Cooldude5231
04-24-2012, 06:10 PM
i have a set of 4:10s i wanna put in my 95 t/a 6 speed.
cruising at 70mph in 6th how many rpms are you spinning??
Chanson
04-24-2012, 06:59 PM
0i have a set of 4:10s i wanna put in my 95 t/a 6 speed.
like 1800 bro its amazing i got 28 mpg driving it home ya its really nice.
so would it be because (i talked to the guy that i bought it from) it has a govener lock posi?:burn:
MEAN LT1
04-24-2012, 10:05 PM
0
Nope. Something's wrong with the car if you roll into it and stomp and not be able to roast 1-2.
Fazz73jr
04-25-2012, 10:38 AM
Traction control on? ? Aka ASR
Jr.Samples
04-25-2012, 10:53 AM
I run
2,000 RPMs at 50MPH in 6th
2,350 RPMs at 60MPH in 6th
2,700 RPMs at 70 MPH in 6th
Exidous
04-25-2012, 01:17 PM
Is there a big gearing difference between a LS1 t-56 and the LT1? With a 4.1:1 rear I get about 1750 in 6th @ 60 with a 25" dia tire.
Edit: What tires are you using?
Turnin20s
04-25-2012, 10:04 PM
I run
What size tire you running??
Mine with a 275/40/17 with 4.10s turns ~1800 @ 60 mph. You sure your not in 5th gear :jest: j/k
Chanson
04-25-2012, 10:05 PM
it has min slip and doesnt have an on off switch? soo ya but ig i just couldnt tell my tires where spinning a buddy of mine watched me take off and ya they were spinning and ig ive just never heard the sqeal because of my subs lol i had my radio off and ya they chirp pretty easily when i take off i love it
Chanson
04-25-2012, 10:06 PM
I run
really dude???? how i dont hit 2000 till bout 70 lol ^.^:cool: seriously sure ur not in 5th lol
Martin@Tick
04-26-2012, 08:29 AM
Nope, as long as its not a 93 model. 94-02 should have the same gear ratios.
Jr.Samples
04-26-2012, 09:25 PM
Really Dude. 6th
Chanson
04-26-2012, 09:41 PM
Really Dude. 6th
:twisted: that sucks bro mine is way lower i dont hit 2000 till bout 70 damn what gas mileage u get then?
Turnin20s
04-26-2012, 11:31 PM
Really Dude. 6th
Are you running a 20" tire?? That's crazy that you are turning those RPMs, do you have a '93 model 6 speed? I know the overdrive ratio on them is different than the later years.
gregrob
04-26-2012, 11:38 PM
dafuq?
WTF is a "governer lock posi" :rolleyes:
wrd1972
04-27-2012, 06:03 AM
I run
No way that can be right.
Mine does 72MPH in 6th at 2KRPM and thats in line with the calculators. You might really have 4.56 gears but there is no way you have 4.10s with those numbers above.
wrd1972
04-27-2012, 06:05 AM
:lol:
ls1 1990 VN
04-27-2012, 11:38 PM
1850rpm @ 100kph/62mph with 4.10s here.
Chanson
04-28-2012, 12:20 PM
dafuq?
no clue thats why i asked i looked it up on google nd dont really understand it but alright lol
bww3588
05-01-2012, 10:08 AM
Really guys...
Gm gov-lock. (Gov-bomb). Google it.
white1999z71
05-04-2012, 05:22 PM
I run about 2200 @ 70 with 4.56s and a 28" tire in 6th
