View Full Version : just curious..
Bnawty00SS
04-23-2012, 06:10 PM
i am planning on using tsp's stage 2.5 ls6 heads. i was told to mill the heads .025, i am using a 231/239 duration cam with stock head gaskets im just curious as to know if im gonna have piston to valve clearance issues with a stock piston? i was told yes and no so far lol!:burn:
PREDATOR-Z
04-24-2012, 07:23 AM
Don't expect more from the net. As a guess, I would say yes there will be PTV contact, or the margins would be too close for comfort.
BOTTOM LINE
MEASURE
mark21742
04-24-2012, 09:27 AM
If your bumping up your compression go for the .025" mill, .040" head gasket and cut valve reliefs....always check you ptv clearance.
