Offset help!!!! NEED ADVICE ASAP!!!!
Old 04-23-2012, 08:23 PM
Murphdizzzl's Avatar
Default Offset help!!!! NEED ADVICE ASAP!!!!
i want to but c6 rims 18x9.5 with an offset of 58 for my 2001 camaro v6 will it work up front? i currently have 20x8.5 forte rims with a offset of 15 and they rub and make really loud grinding noises when turning and going straight simetimes. and my mom and her bf who is pretty much a mechanic thinks theyll rub since my 8.5 wide rims r already rubbbing. on my current rims i have 255/35/zr20 what size tire would i need for the c6 if they fit?
thanx for an advice!!!!
Old 04-23-2012, 08:42 PM
VinR1's Avatar
Your current wheels/tires rub because the offset is way too low (I bet they stick out) and the entire combination is a good 2" too tall
The C6 wheels will fit fine - 275/35 would be a good size to run
Old 04-23-2012, 08:50 PM
thanks for the info gatta buy them by tomorrow and i didnt know if i would need a spacer up front since the offset is a little high. and what about 265/35 cuz i found a set for about $500? SEMPER FI r u in the marines?
Old 04-23-2012, 09:58 PM
VinR1's Avatar
Yeah, I joined the club
265s will work but may look a bit 'stretched'
Old 04-23-2012, 10:04 PM
thats kool i was in for about a year and got injured i enjoyed it san diego was a blast!
when u say stretched is that that just a look issue or what?
Old 04-23-2012, 10:10 PM
VinR1's Avatar
Yeah, just a visual thing. 1cm wont make a huge difference
Old 04-23-2012, 10:22 PM
is 1cm the difference from 275 and 265
Old 04-23-2012, 10:25 PM
VinR1's Avatar
Yes sir
Old 04-23-2012, 11:00 PM
what wheel and tire setup u have on ur car?
Old 04-23-2012, 11:10 PM
VinR1's Avatar
In the sig pic? 17x9.5 ZR1s 56mm offset fronts and 17x11 36mm rears. I sold them two weeks ago and currently have 19x8.5 RPM 505s 38mm offset all around
Old 04-23-2012, 11:19 PM
with the 56mm offset what tires did u have and did u have any rubbing when turning?
hers a pic of mine currently, not a good pic idk how yall make yalls pics so big
Old 04-24-2012, 06:49 AM
VinR1's Avatar
No, none at all
