Rebuild ls1
Old 04-23-2012, 09:48 PM
Phinox's Avatar
Default Rebuild ls1
I just bought a 2000 trans am the motor was rebuilt 30000 miles ago and a lifter has gone bad. I'm thinking of just rebuilding the whole thing. I got 4k to spend all I really want is to produce between 400-450hp at the wheels. Do y'all think it can be done and any suggestion on how to do it thanks.
Old 04-23-2012, 09:50 PM
Phinox's Avatar
I forgot I have a 6speed manual trans
Old 04-23-2012, 10:01 PM
garygnu's Avatar
do a leak down or compression check,maybe the short block is ok.get some new lifters from Texas Speed .check out one of their head/cam combos.get some cnc heads or some tfs 220 heads.a fast intake for $840,and a custom cam from the cam experts on this forum..you will need a bigger fuel pump and injectors .or check out vengeance racing for a head/cam pkg.
Old 04-23-2012, 10:20 PM
Phinox's Avatar
Thanks I'm pretty much a noob at this I do know that the car already has a ls6 intake so should I still get the FAST intake and what kind of cam should I get. Should I get forged internals
Old 04-24-2012, 01:16 AM
SF 1HOTLS1's Avatar
If its just a lifter replace those and do a head cam swap and keep your ls6 intake. **** if the motor was just rebuilt not to long ago save your money.
call Texas speed, they will set you up to what your looking for.
