1999 SS/Z28 Camaro for Sale H/C boltons 428RWHP, 377RWTRQ
Year: 1999
Make: Chevrolet
Model: Camaro
Price: $12500
Mileage: 85000
Private or Dealer Listing: Private Listing
Location (State): WI
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
LSX Intake Mannifold by Comp Cams and FAST
Custom Ported & Polished LSX Throttlebody by Comp Cams and FAST (102mm)
High Flow Billet Aluminum Fuel Rails and Crossover by LS1 Speed
Fully Ported and Polished RGR Stage II Aluminum Race Heads
2.02/1.57 Valves, Patriot Gold Dual Lift Valve Spring Kit, Chrome moly Pushrods
Custom Grind Cam- 235/240 .621”/.609” 111 LSA+1.
SLP Racing Double Roller Timing Chain
SLP Racing Oil Pump
ASP Underdrive Crank Pulley
Engine Tuned by West Bend Dyno Tuning.
West Bend Dyno Tuning is a world class dyno tuning shop, they have tuned and built cars featured in Hot Rod magazine, Forglines website, and also tuned a car that set/holds a world record for landspeed last august in the blown gas modified division (i actually work for the car shop that owns this previously mentioned car, and watched them tune the car in 3 pulls from 560hp to just under 1000)
Suspension: Bilistein Shocks
BMR Lowering Springs
BMR Sub Frame Connector
BMR Lower Control Arms
BMR Panhard Bar
Hothkins Strut Tower Brace
1LE Sway Bars
Spohn Torque Arm with Drive-Shaft Loop.
6-point roll cage by Kenny Brown, welded in
Transmission: B&M Ripper Shifter
Energy Susp Trans Mount
ACPT Carbon Fiber Drive Shaft
Centerfore Dual Friction Clutch (rated for a 1000hp)
Fidanza Aluminum Flywheel
Updated GM Hydraulics
Differential: G2 Differential Cover and Stud Kit, 4.10 Gears
Tires: Rear 315's Nitto NTO5
Front 275 Nitto NT05
the cars last dyno was 4/4/12 and it put down
428 RwHP
377 RwTRQ
85,000 Miles
About 20,000 miles on Modifications
Dishonest seller??? when you asked for the vin me and you both found out it wasn't a "true ss" thats was honest as it gets and was when i first found out it wasn't an ss not that it matters anywas as the collectibility of the car is shot with all the aftermarket parts on it. Just because we can't agree on a price doesn't mean you have to act like a child about it... you said yourself you found a better car for less money quit wasting my time and buy the other car
