Manual Transmission - Tick remote bleeder question...
This may be a dumb question but how does one close the bleeder? I have it screwed all the way in but the fluid keeps coming out...
jthunderz28
04-24-2012, 01:04 AM
Are you using an 11 and 14 wrench combo to close it? I just installed one over the weekend when me and a buddy put in my LS7 Clutch. Make sure you hold one end with a wrench and tighten the other end with the other wrench. It shouldn't have fluid coming out.
This remote bleeder should be mandatory for all when doing a clutch.
^^ +1 no problems with mine. I had to crank it kind of tight the first time because of the thread sealer they put on it.
Uneverknow
05-03-2012, 10:36 PM
my remote bleeder works great. only thing i'm thinking of doing is finding the correct size speed bleeder so i only have to pump till the airs all out the line. anyways you probably just need to crank it down tighter. good luck.
Tick Performance's bleeder already has a speed bleeder.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
