Generation III Internal Engine - Trunnion upgrade geometry
View Full Version : Trunnion upgrade geometry
ws6_4800
04-24-2012, 12:11 PM
I got the stock cam and valve geometry. I recently bought trunnion upgrade and noticed a difference in approx. 1/8" (.125) in the distance to the thread when the bolt is in the rocker. I know the lifter preload would absorb some of the difference, but I'm almost tempted to buy .125 shims to bring back to stock geometry. What are your thoughts?
ZQ8LS1
04-25-2012, 11:25 PM
IMO is a non issue as the bolt has to go thru the rocker stand before it even gets to the threads that are in the head.
bww3588
04-26-2012, 08:13 AM
As long as the rocker is sitting on the stand correctly, your geometry should not change.
dodson55
04-26-2012, 09:00 AM
the geomety does not change as the trunion upgrade has the bolt coutersunk in the trunion which makes the bolt stick out the bottom farther that is one of the reasons they give you shorter bolts just use the bolts that come in the kit and you will be fine
ZeeOSix
04-26-2012, 12:35 PM
You are using the new bolts that came with the Trunnion Kit ... right? Do NOT use the stock rocker bolts.
