MikeFSKSpeed
04-24-2012, 01:38 PM
Hey whats up everyone,
We have an extensive stock of POR-15 Products in stock and we are offering 10% off right now, as well as free shipping on Gallons.
PM Me with any questions!
Thanks, Mike
POR-15® is a high-tech, high performance rust-preventive coating designed for application directly on rusted or seasoned metal surfaces. It dries to an incredible rock-hard, non-porous finish that won't chip, crack, or peel, and it prevents rust from recurring by protecting metal from further exposure to moisture.
Applications:
Automotive: chassis, doors, floors, trunk areas, suspension, engines & fuel tanks.
Industrial: heavy equipment, truck components, trailers, fuel storage, rebar, steel forms, concrete, storm grates, transformers, wastewater management.
Marine: decks, bilges, hulls, steam pipes, chain lockers, masts.
Home: seals cracks in basements and foundations, garage floors, roofs, HVAC, pipes, beams, home appliances.
Also excellent for sealing and repairing fiberglass!
POR-15® is sensitive to UV light (sun) and must be topcoated for prolonged exposure to sunlight.
Topcoating is not required for areas not exposed to sunlight.
NOTE: Make sure the areas to be painted are properly prepared for a POR-15 treatment.
http://www.skspeed.com/SearchResults.aspx?ManufacturerID=POR-15
Thanks, Mike
Applications:
