PCM Diagnostics & Tuning - EFI Live - Abuse Management Table?
Bill00Formula
04-24-2012, 05:34 PM
Just saw this table for the first time.
Says upper level - 6,600 rpm
Lower level - 6,500 rpm
Abuse mangement commanded fuel .833
Does anyone know anything about this. Is this ok to leave it where it is?
Thanks
joecar
04-24-2012, 06:45 PM
Hi Bill, what year/vehicle/ECM...?
Bill00Formula
04-24-2012, 09:40 PM
2000 formula, 6 spd
joecar
04-25-2012, 10:37 AM
Are you referring to the Abuse tables in the transmisson segment...?
Higgs Boson
04-25-2012, 10:56 AM
Just set abuse tables to a setting that can't be engaged, like enabled over 7500 or something.
Bill00Formula
04-25-2012, 07:03 PM
Thanks, It's a folder under engine calibration called abuse management.
It comes oem so that abuse management can only be activated if throttle position is greater than 100%. I don't change anything in that table. Never been a factor or issue.
Higgs Boson
04-27-2012, 09:37 AM
Not all cars/trucks are the same calibration from the factory.
Yes, that's correct. The LS oem parameters that I've seen, including a 2000 Formy have B1207 set to "0" and so abuse management is disabled unless you're sitting still. Out of curiousity, which ones come oem with Abuse management enabled above zero kph/mph?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
