New LS1 Owners - Newbie Tech - Cam??
View Full Version : Cam??
BadxLS1
04-25-2012, 01:04 AM
Okay I Have a 2000 Z28 the mods list
Pacesetter LT's
Ls6 intake
4.11 Gears
What I want to do now is try and find the best cam for my mods,
But I want a real lopy sound. I know for a big cam I need a stall and
Plan on getting one. What's the biggest I can go and still run A/C??
Thanks,
Mark
lemons12
04-25-2012, 01:11 AM
Pacesetter LT's
Ls6 intake
4.11 Gears
Thanks,
Mark
You don't need a cam for your current mods.. You need a cam to reach your goals and budget.
Future mod plans? Intake? Heads? Etc...
DD? Track car?
Budget for supporting mods?
You can run the largest cams available (Ms4/TREX/etc) and still run AC.
A converter is a must BEFORE or at the same time as a cam, PERIOD... Yes even something like a 224, PERIOD.
With the info you provided... Anything from an ls6 cam all the way to an Ms4 would work perfect. ;)
BadxLS1
04-25-2012, 01:49 AM
Yea was looking at the MS3 and a 3600 stall,
And wanted to do the FAST 102 combo.
Thanks for your input.
bww3588
04-25-2012, 02:08 AM
If your looking for heavy chop, good driveability and good power, look into the gm asa cam. Proven cam and uses yellow ls6 valve springs. It's easy on the valve train, great for a daily driver and makes great power.
bww3588
04-25-2012, 02:09 AM
Also, it would work good with your ls6 intake. I would have went with 3.73's in The rear in an auto car, but should still drive great anyways.
TransAmcoupe98
04-25-2012, 05:48 AM
Don't necessarily need a big cam for alot of lope. I had a 222/224 on a 112 lsa with a 110ICL and it loped like a sumbitch, even more than my other Z06 did with a 227/231 @ 111 LSA, it had a 106 ICL. Many factors determine your "lope". Search around the stickes...actually, go read the "Cam Guide" sticky in the Gen III internal engine.
wooddaniel
04-25-2012, 06:09 AM
With a stock cube motor you dont really need to do the 102 combo. It won't really benefit you that much. As for the cam, what are your goals for the car? I personally went with a comp custom grind medium sized cam because I drive my car daily and didn't want to lose too much driveability. It all depends on what you are doing with the car. Do your research, and make sure you change out the springs/pushrods while you're at it. And as someone stated above a stall is absolutely necessary.
bww3588
04-25-2012, 08:04 AM
The 102 will work on any sized motor. There is a reason why they replaced the 90/92 with it. You will gain more with the 102 over the 90 or 92.
With the stupid prices people are wanting for the 90 setups, you may as well spend a little more and get the 102 setup.
lemons12
O yea? How does a "sumbitch" lope exactly?
:08 seconds
http://www.youtube.com/watch?v=BGfcrLl7Pho
mjs1012
04-25-2012, 08:19 AM
^ now i understand we all wanna build our cars to go faster and run better but that dude in that video is a selfish asshole. $2500 a month on the car and you live in a shit hole, struggle to pay bills and expecting a kid....cmon man where are your priorities. flame me if you want but thats absurd.
Sorry for going off topic.
BadxLS1
04-25-2012, 03:50 PM
The car is my daily driver, but I already installed 4.11 gears, which effected the dd tremendously. I have the motor out so wanted to go ahead and swap the cam. If I was to get the MS4 what springs, and pushrods would I need?
wooddaniel
04-25-2012, 04:00 PM
I would call someone at either Texas Speed or Maryland speed, tell them what you are doing and they will hook you up with everything you need. Those 2 vendors are the ones I have used. If you're planning on buying from a vendor that is. I got everything for my H/C Swap on my old WS6 out of the classifieds here cause Im poor.
BadxLS1
04-25-2012, 04:11 PM
Just don't want to shove out all that money on the classifieds here and get shafted for a pretty good chunk of change, rather spend the extra money and know what I'm getting.
wooddaniel
04-25-2012, 04:14 PM
Trust me I would have bought everything from a vendor if I could afford it. I did make sure to get springs/pushrods and the cam brand new. The heads were mildly used 243's that I found on here.
BadxLS1
04-25-2012, 04:21 PM
Im also on a budget, me and my wife just moved into a house so thats a big piece of my checks gone. Do you know if the stock heads are the 853's?? What kind of power difference did you see with the 243's?
I dont know shit about heads. lol
wooddaniel
04-25-2012, 04:24 PM
What year is your car? 98= 806 heads. 99=853. 2000 and up= 853-241 casting. The # is going to be on the side of the head you should see it. I probably gained around 20 RWHP with the 243s, it would have been more had I ported them. My cam wasn't that big though, My car made 424/389
Just read you have a 2000. You have either 241 or 853 casting heads. Also if you look on here you can find 799 heads periodically, which dont have the sodium valves but are essentially the same as 243's. Hope this helps.
BadxLS1
04-25-2012, 04:53 PM
Yea i have the 853's. Would i need to change heads with the Ms4??
wooddaniel
04-26-2012, 07:22 AM
You don't have to, but it would definitely help
BadxLS1
04-26-2012, 05:53 PM
Would the mS4 be to big? Would hit hit the valves?
Don't mean to ask so many questions, just want to know before I spend the money.
garygnu
04-26-2012, 08:51 PM
the ms4 will fit .you get the best deal if you buy a cam kit with all the correct parts .it will effect your gas mileage ,and you need to monitor and change your springs sooner then mellow cams .it requires a good tuner .you should get some trunnion bearing upgrades with a more radical cam like the ms4.
bww3588
04-27-2012, 02:07 AM
The ms4 cam is not going to be very dd friendly...you don't need the biggest donkey dick of a cam you can get your hands on. The ms4 will give you tons of top end power but lack in the lower end.
For a dd, you need a smaller cam that will make power under the curve. I'm not sure how often your car sees 6k rpm's on The way to work and the grocery store but the ms4 lives up there.
bww3588
04-27-2012, 02:09 AM
Look around in the dyno section, study some dyno graphs and compare thoes graphs for both the ms series cam's and smaller cams. Particularly the torque curve. A broad flat torque curve is going to be the best setup for a car that mainly sees the street.
wooddaniel
04-27-2012, 07:05 AM
Yeah it's not all about which cam makes the most power. Its about being set up right. My car was a DD, my cam was 228/232 595/595 112 LSA. It loped like crazy but it made good power under the curve and was driveable every day. Also, you doing any suspension work to the car? Its pretty important to put all that power to the ground.
