Conversions & Hybrids - Any G-bodys running F-body accessories???
veltboy618
04-25-2012, 01:21 PM
Are there any G-body cars running F-body accessories on their engine with the A/C compressor & Alt in the stock location? I have a 5.3 & I already have my frame notched for the compressor but I want to see if the Alt clear the power steering box or interfere with anything else. Pics will help a lot
01cherryreds10
04-25-2012, 02:22 PM
What mounts do you have?
veltboy618
04-25-2012, 02:45 PM
I don't have any mounts right now. I'm trying to see which mounts will work for what I'm trying to do before I go spend some money on some that will not work. Are there certain mounts that I should stay away from while trying to get both of them down low?
bigmandengo
04-25-2012, 05:24 PM
I have f-body accessories and the alternator clears the steering box fine. Im also running 1" setback mounts and kwik perf. top mount ac.
85GPLEf41
04-26-2012, 12:18 AM
I ran into issues with the transdapt 1in set back plates and stock clamshells. The alt hit the alt in the stock position. To solve that issue i used the Speedway motors ls1 alt high mount kit..As for a/c i'm not going to figure that out right now, BUT i do have the Kwik performance a/c mount kit in mind.
the_merv
04-26-2012, 01:03 AM
I have the normal plates you see everywhere, no issues with the alternator. I'm using Fbody accessories, no AC.
CBRAKLR85
06-02-2012, 05:25 PM
Any pictures of your set up?
Thanks
TJ
the_merv
06-02-2012, 10:18 PM
About the best I got..
http://i103.photobucket.com/albums/m129/the_merv/MCSS/EPSCAMENGINEINSTALLED.jpg
66chevelle_02SS
06-04-2012, 03:52 PM
I am using the Dirty Dingo mounts. There is no way you can run the a/c in the stock location. I am also runnign the truck accessories. Clearance is good with the F body pan.
