Procharger D1SC LS1 J-Bracket Pros and Cons?
So I am in the process of looking for a bracket for D1SC Procharger. I was leaning towards the aster bracket which I know is the best but due to finances I am now going with a J bracket from Procharger. What are the pros and cons of this bracket? My car has the stock bottom end so i am planning on only running 8 or 9 pounds of boost. I will be going with an FMIC as well. Let me know your thoughts guys!
Thanks
Thanks
Save for the Aster Bracket. Worth every single penny, especially when you decide down the road to turn up the wick. I can't post the video and it may be in my old build thread but you would be very suprised on how much those belts stretch under full load.
Edit: Video is on this page of my build thread
https://ls1tech.com/forums/forced-in...e-boost-9.html
UNDER PRESSURE MOD
I agree, Aster's bracket is worth every penny.
I don't have any installed pics, but it is a rod that runs from the driver-side forward corner of the oil pan (bolted down by one of the oil pan bolts) to the back-side of the supercharger on the flimsiest part of the J.
Its a simple fix and seems to stop any sort of flex.
You can see a picture of the rod in the lower left of this picture (yes I know I suck at linking).
https://ls1tech.com/forums/parts-cla...tup-cheap.html
I've never had slip problems due to flex. I spin the D1 to 62k at 17 psi and have done so for about 40k miles now. Possibly, I'm just lucky.
Here's a pic of my SDCE J bracket with the rod to the oil pan. http://mycarpics.shutterfly.com/277
I would either send you J bracket to SDCE and let them add their spring tensioner, or save up and get the astar J bracket.
Here's SDCE's spring tensioner http://mycarpics.shutterfly.com/211
If it were me I would save for a couple more weeks and do it right and get asters bracket. I know it sucks to spend that kind of money but you will save money in the long run if you just get aster bracket the first time.
I hear that the brackets slip and dont account for the belts movement.....that belt is constantly changing its size. Get above 8-12 lbs and your going to start slipping....and having bearing issues and all kinds of nasty bullshit...it is the worst part of the kit. I have one and I cannot even sell it. I am getting the aster bracket. Among other things....in the end you just do not wanna have to be tightening the belt all the time. 3-4 week wait time.
Great reference vid. http://www.youtube.com/watch?v=WqyT8dYzAkM
http://www.youtube.com/watch?v=VRvT9...eature=related
