3rdgentug
04-25-2012, 08:33 PM
1968 camaro coupe
primer black ( horribly done too , you can tell in the picture , i actually thought it to be rattle canned )
fuel sump
mini tubbed
weld wheels
newish tires
body is good but things like the doors and fenders, hood and trunk all need to be aligned ( im picky about that and they are all off )
all the glass is good
original sb car but has a 454 with a cam and a quadra jet now , nothing fancy under the hood
new exhaust was run under the car , headers, to true duals with flowmasters
stock turbo 350 trans with a b&m shifter thats fubar
ford 9 inch rear end spool with 4.11 gears
stock suspension with slapper bars
no front grill , headlights or bumper
runs n drives
interior is completly shot, and i mean every piece basically needs to be replaced just ragged out
use to have a cage in it that was cut out and removed
does have working stock gauges
center console is junk too , front seats there but bad shape, rear seats gone
i was told the only a small bit of rust in the floor pans but its been patched before
trunks suposse to be solid as well as door pillars, a pillars, quarters and under the front windsheild
(i asked about those spots specifically)
stock hood with a blended in cowl , looks ok from the front back and sides but underneath its obvious it not a real pin on cowl hood
i feel hes a little bit high on the car and after weeks of contact with him back and forth he hasnt budged on his price.
i want the car , he wants to sell it , i want to make him a fair cash offer and not be insulting
what do you think its worth ?
fuel sump
mini tubbed
weld wheels
newish tires
runs n drives
