LT1-LT4 Modifications - Valve cover issues
bigz28man
04-25-2012, 09:44 PM
I'm having major issues getting valve covers to fit on the heads I have. The inside webbing of the valve cover does not clear the rocker arms, anyone have this problem and what valve covers should I go with. I have AFR 195cc CNC ported heads on my 396 lt1. My alternator is in its stock location so the passenger side valve cover needs to be notched out. I Would prefer the valve covers to be polished aluminum.
96z28_lt1
04-25-2012, 10:12 PM
hmmm well as far as another valve cover im not sure with the alt in stock location although i believe i've found a thread about this a while ago when i was looking into rock arm and i believe if you dremel out the intake side of the valve cover webbing it should work, don't hold me to it though just thought i'd give you a response maybe someone else can back me up with that though
Rob94hawk
04-25-2012, 10:27 PM
I'm assuming you're using the stock covers so I cut the long part of the valve cover like this and they fit perfectly with my rockers. Hope this helps (note that I googled this pic but it's the same thing I did):
http://i29.photobucket.com/albums/c254/stealthformula/LE2025.jpg
bigz28man
04-25-2012, 11:29 PM
thanks for the help, i'll be pulling out the dremel
katz_2003
04-26-2012, 08:14 AM
I am running the fab cantons. They will clear everything. There are pics in the link in my sig if you want to take a look at them
bigz28man
04-26-2012, 09:30 AM
is the canton part # 65-206
SS RRR
04-26-2012, 10:00 AM
You can either cut them out or take a set of pliers or vice grips and straighten the 90* lip on each brace. That way you can maintain full rigidity.
katz_2003
04-26-2012, 10:11 AM
Yes that is correct! I found mine on eBay for around 180 shipped
coolmanvette75
04-26-2012, 09:17 PM
Canton if you keeping the alt in the same place. If relocated, I got the ebay specials and they looks great and dont leak. Just get a good gasket...
warriorcustoms
04-26-2012, 10:34 PM
Got my proform 141-130 covers in the other day :) Youll need to grind/clearance the back of the alternator google search turned up plenty of info
spordee1
04-27-2012, 12:33 PM
I am running platinum Yella Terra rockers, I had to order their valve spacers to clear the rockers. Good luck.
bigz28man
04-29-2012, 04:56 PM
Spoke withwith buddy whoof works for jessel, he milled out the webbing and they go on with no issues. I'm still going to go and get the canton covers, will send them out to be polished, anyone know of a good polisher?
skippydn
04-29-2012, 06:23 PM
I have the billet specialties flamed tall valve covers on my afr 190s. Madman notched the pass one for the alt. Im running the crane gold rockers with no issues. And cantons suck ass. Nothing but leaks from day one.
warriorcustoms
04-29-2012, 10:20 PM
I think theyre just plain ugly LoL The proform ones Ive got are polished Had to do the chevy ones because the plain polished ones were on back order Any of em look way cleaner than those cantons
