85mcss
04-26-2012, 09:32 AM
Due to lack of information on this topic I've decided to make a thread detailing my swap from 700R4 to 4l80E behind my SBC.
I fist started out with buying an 04 4L80E out of a 2500HD truck with 45K miles on it for $600. I then ordered a Transgo HD2 kit for it and installed it. (it was actually really simple with the directions and the help from this thread:
http://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/ecsb-4wd-4l60e-4l80e-424904/ )
I plan on using the Jakes manual controller and hopefully re-using my Iceman 700 R4 crossmember. The stock converter should do for now until I get the car tuned. Maybe later on I'll purchase a stall. The driveshaft will have to be modified as well.
700R4 coming out:
http://i451.photobucket.com/albums/qq231/somcamaross/IMG_1043.jpg
700 next to the larger 4L80E
http://i451.photobucket.com/albums/qq231/somcamaross/IMG_1048.jpg
700 stall converter on the right, Stock 4l80E converter on the left. I later found that my flexplate was a 153 tooth and the 4l80E flexplate was too large. Had to order a new 153 tooth flexplate with an 11.5" converter bolt circle for a 2-piece RMS
http://i451.photobucket.com/albums/qq231/somcamaross/IMG_1044.jpg
Looking at the back of the block
http://i451.photobucket.com/albums/qq231/somcamaross/IMG_1041.jpg
http://i451.photobucket.com/albums/qq231/somcamaross/IMG_1075.jpg
Shift linkage installed on the 4l80. The stock rear shift linkage was pulled from the 700 r4 and works on the 4L80 with a bit of massaging of the holes to make them line up with the holes on the 4l80e pan.
http://i451.photobucket.com/albums/qq231/somcamaross/IMG_1049.jpg
http://i451.photobucket.com/albums/qq231/somcamaross/IMG_1050.jpg
A few during the Transgo HD2 install
http://i451.photobucket.com/albums/qq231/somcamaross/IMG_0944.jpg
http://i451.photobucket.com/albums/qq231/somcamaross/IMG_0949.jpg
http://i451.photobucket.com/albums/qq231/somcamaross/IMG_0954.jpg
http://i451.photobucket.com/albums/qq231/somcamaross/IMG_0960.jpg
measuring the flexplate
http://i451.photobucket.com/albums/qq231/somcamaross/IMG_1071.jpg
700R4 coming out:
