Conversions & Hybrids - Custom Serpentine Accessory Drive.
fox12303
04-26-2012, 09:56 AM
Not sure how much interest there may be in this but i've developed my own accessory drive for LS swaps. The A/C bracket and tensioner would work with the truck alternator/power steering bracket, sort of an A/C relocation kit. The complete setup will not work with OEM efi intakes as shown. For anyone using a conventional carburated intake this setup is perfect. Give me some feedback, good or bad. Based on feedback from here and other forums I may apply for a patent and produce these on a limited basis.
Here's the link to it directly:
http://ls1tech.com/forums/16242884-post11.html
Or you can read about my swap which contains the above info for the drive setup.
http://ls1tech.com/forums/conversions-hybrids/1539794-72-chevelle-malibu-ls-swap-w-fast-ez-efi.html
Thank you.
http://ls1tech.com/forums/attachment.php?attachmentid=351298&stc=1&d=1335452039
To reply to the posts below, the tensioner bracket has multiple holes in it to set belt tension. I did not slot it out of personal preference but it could easily be slotted in the future. I will post a link in the LSx carb section. That was a great suggestion, thank you TomM.
downset71
04-26-2012, 01:26 PM
looks great! my question is - it looks like you used a stationary pulley. how do you loosen the system to get belt on and off?
TomM
04-26-2012, 01:52 PM
It will not work with OEM efi intakes though so it may have too limited an application perhaps.
I think you answered your own question. You might be better off posting in the carb forum, you'll probably get a better response. I think most like the benefit if EFI........but this is just my opinion, what do I know... :D
Nice looking setup though, good job on the R&D..........
T,
fox12303
04-26-2012, 10:39 PM
To answer downset71's question, I did not slot the bracket rather I drilled multiple holes into it to set and hold the tension on the belt. If you remove the tension bolt the bracket will pivot out of the way to remove/install the belt. The tensioner bracket is held into place with two bolts.
Thank you for the compliment and question.
fox12303
04-27-2012, 10:30 PM
Just wanted to point out this feature. The A/C bracket and tensioner would work with the truck alternator/power steering bracket as sort of an A/C compressor relocation kit.
tta656
04-28-2012, 02:54 AM
Downset71 see arrow...
