Nitrous Oxide - nitrous controller? retard ?
View Full Version : nitrous controller? retard ?
SPOOLED UP
04-26-2012, 10:17 AM
what is everyone using for a lsx 00 model?
Need it to control the n20 and retard the n20 system. What is out there and the easist/best one that is most commonly used?
thanks in advance.
I would also like to have it for my wideband and lean shutdown.
Fbodyjunkie06
04-26-2012, 11:15 AM
Your post is hard to follow and understand.
Are you asking what controller is best to progress the nitrous and control it's on/off settings like a progressive with a built in window switch or just a just a way to control when it comes on and when it cuts off like a normal window switch.
It also sounds like you want to retard the timing? To do this you would need a timing tuner or timing twister.
MSD makes one, there is another company that makes one. It says horsepower in a box on the control box I forgot the companies name and the LNC-002 from Lingefelter which is a two step rpm limiter and a timing retard controller all in one.
pokaspeed
04-26-2012, 11:21 AM
Thunder racing makes the timing tuner, dont they?
armyboyatc
04-26-2012, 11:25 AM
Call Nitrous Outlet. They can hook you up im sure.
robsquikz28
04-26-2012, 11:27 AM
NOs mini controller or a nitrous outlet progressive controller. But you will then need a timing retard box. But N20 outlet im sure will chime in and help you get both.
blue99fbody
04-26-2012, 02:21 PM
full throttle makes it.
i run it paired with a fjo and like it
TransAmcoupe98
04-26-2012, 09:13 PM
Lingenfelter has a good timing commander. Its $276.00 on nitrousoutlet.com
warriorcustoms
04-26-2012, 11:05 PM
x2 Nitrous Outlet has an Awesome tech support Give em a call
Chris@NitroDaves
04-27-2012, 04:46 PM
I would suggest going with a progressive controller...either our brand [ $229.99 ] or the NOS Mini [ $245.95 ] and then pair it with the best option for pulling timing when only spraying would be the Lingenfelter unit [ $274.95 ]. Either controller with that timing device will suite your needs to a T.
PS: Thanks for the compliments above guys!!!
fst_ls1
05-07-2012, 09:35 PM
Nitrous outlet !
