Dynamometer Results & Comparisons - Does this sound about right? 243's Torquer V3
streetknight2
04-26-2012, 01:06 PM
Took my car to dyno. Just wondering if these #'s sounded about right.
02' Camaro, stock bottom end, 243 heads, Torquer V3 cam, Long Tubes, SLP LM exhaust, Auto thru 3600 stall, and 9" Ford Rear End.
It made 385 RWHP and 407 RWTQ
thunderstruck507
04-26-2012, 01:22 PM
Have a graph? What brand dyno? Converter locked or unlocked? Ported or stock heads?
streetknight2
04-26-2012, 01:30 PM
I will see if I can get it, dynojet, no clue, and supposed to be PRC stage 1 ls6's
*02WS6TURK*
04-26-2012, 05:23 PM
My buddy has a 02 Camaro A4, TV3, 799's and 3600 stall. He put down 420+rwh on a mustang dyno.
derrickman05
04-27-2012, 11:06 AM
Ive got a V3 as well. I'm just trying to decide on a good head to go with it. Between AI243 and a prc 227
dont z20h8
04-27-2012, 12:49 PM
Sounds low IMO
streetknight2
04-27-2012, 12:53 PM
I'll get more info, car is still at the tuners, having a trans issue, so that may be part of it. I did hear the 9" rear sucks up about 15 HP
thehazz12
04-27-2012, 01:01 PM
I would agree with the others that said that seems low. You should also look into swapping to a bigger TB if you're still running the stock unit.
Edit: And was this a mustang dyno or a dynojet? If "mustang dyno", that's probably accurate as that would be 425-ish HP...
dont z20h8
04-27-2012, 01:30 PM
He said it was a dynojet i think
MikeG
04-27-2012, 02:02 PM
Torque is solid, HP is low though.
reeperz28
04-27-2012, 06:57 PM
Unlocked converter would make that kind of torque with that much lower horsepower. Just get some track results and see what it can do
streetknight2
04-27-2012, 07:07 PM
I think that was with converter unlocked, the trans issue I'm having is the converter doesn't lock until it goes into 4th, then it locks automatically. If you put the shifter in OD, it actually shifts out of 3rd after a split second and goes right into 4th and TC locks. Falls on it's face.
Ugh, hope it gets straightened out soon.
streetknight2
04-27-2012, 07:08 PM
reeperz28
04-27-2012, 07:15 PM
Yea my fears are probably going to haunt me also, I'm Installing ported 243's and a 226 234 cam and fast 92/92. Still rocking the stock 100k transmission with a mild stall. Yea when come tune time its gonna be bad lol. I willing to chance it I guess.
thehazz12
04-28-2012, 04:58 AM
Oops. You're right...guess I need to read more carefully.
