Cadillac CTS-V - Gauges
View Full Version : Gauges
GFallen
04-26-2012, 06:31 PM
Picking up a maggie soon and looking into gauges... any thoughts? really only wanted a boost gauge but was thinking possibly adding a fuel pressure one also. I'm a simply guy. lol pics and ideas would be great. and where to purchase from. thanks in advance.
Onefast V
04-26-2012, 06:37 PM
a boost gauge would be more of a pretty thing to look at then super useful. I would install a wide band O2 and do a digital AFR gauge.
GFallen
04-26-2012, 06:57 PM
Where can I buy them from? I heard of the wide band...thanks and where did you mount them?
raven154
04-26-2012, 07:19 PM
I have a single boost gauge on the A pillar.
http://i43.tinypic.com/14prms.jpg
http://i43.tinypic.com/166n1s.jpg
raven154
04-26-2012, 07:24 PM
Modified the stock a pillar trim and relocated the Bose speaker higher in the panel. I have another one that is made, just not covered if you are interested.
1BADCTS
04-26-2012, 07:37 PM
I did a dual pillar setup using interceptor gauges...
http://i33.photobucket.com/albums/d90/mark_woodruff/9d873664.jpg
http://i33.photobucket.com/albums/d90/mark_woodruff/726db645.jpg
http://i33.photobucket.com/albums/d90/mark_woodruff/455af7af.jpg
http://i33.photobucket.com/albums/d90/mark_woodruff/7b5befed.jpg
http://i33.photobucket.com/albums/d90/mark_woodruff/6ea36c8a.jpg
Onefast V
04-26-2012, 07:52 PM
Innovate motorsports sells wideband kits
DMM
04-26-2012, 09:04 PM
Damn, those things look good! What gauge pillars did you guys use? I think I remember hearing the 89-99 Chevy truck fit the best? Also, where did you guys find the fabric to recover the A-pillar?
I have an AEM wideband that I got from summit, I only use it for tuning though. It was the cheapest one that reads Lambda as well as AFR (have to log in Lambda for Ethanol blended fuels when tuning) so you might be able to find something a little cheaper if you are looking for a strictly AFR gauge.
1BADCTS
04-26-2012, 09:32 PM
I used a cheap auto zone generic pod and a hairdryer to heat it up and form it to the pillar... And some flexible bumper bondo to blend it in. Right now it's covered in felt, but I have a used headliner I bought from another member to get a more factory match one of these days.
DrSpeed
04-26-2012, 09:49 PM
Here's the wideband that I used:
http://www.stackltd.com/instruments.html#lambda
http://www.stackltd.com/aux_gauges_2011/ST3401.png
And oil pressure gauge:
http://www.stackltd.com/instruments_pro_control.html
http://www.stackltd.com/images/pro-control_example.png
STay tuned for a write up.
raven154
04-26-2012, 09:50 PM
I glassed mine from scratch and bought some material that matched as close as possible. The factory cloth is not available from any supplier I have found. My mom did upholstery for over 20 years so she can get lots of factory stuff but this stuff was hard to find. Honestly you don't even know it's not factory if you didn't know what it looked like before hand.
itsslow98
04-26-2012, 10:41 PM
Never seen any gauges in the V that actually looked good. If you have to do one do wideband over any other.
JayBirdWs6
04-27-2012, 06:39 AM
:cool::thumb:
I have a dual pod that I've had for years that I was going to use on my 2nd TA but never did. I need an extra Tan A Piller because I think I'm going to use it finally.
ichpen
04-27-2012, 06:57 AM
Yep wideband AFR is the most useful. Having said that I wish I'd stop staring at it and running over neighbours in my street.
I have 2 AEM gauges, boost/wideband. Now thinking of getting the new soon to be released AEM boost/afr integrated gauge and adding fuel pressure.
I like the look of plx gauges but pain in the arse to hide those 'modules' they each have. With AEM everything is built into the gauge body, nothing to hide other than wiring.
