Drag Racing Tech - Front spring question
View Full Version : Front spring question
Camarokid08731
04-26-2012, 06:32 PM
i currently still have the factory springs and struts in my car. i was looking online at suspension and seen moroso makes a "trick spring". has anyone installed these yet? im curious to see if anyone has any feed back.
RamAir95TA
04-26-2012, 07:34 PM
FYI f-body's don't have struts.
Link to said "trick" spring?
TurboStangJON
04-26-2012, 09:18 PM
If you're talking about the 47240 Moroso spring I'd skip them. Just buy a good coilover like a Strange or Afco and use a good coil over spring with a rating and height for the type of car your building. I have had good luck with Hypercoil springs in the past.
GIZMO
04-26-2012, 09:31 PM
I tried those when they first came out in the late nineties. They didn't do anything for me. As stated by others, coilovers are a much better solution.
Boosted Firehawk
04-27-2012, 11:40 AM
What do mean they don't have struts? Up front is a spring and strut combo. It's not a coil over? A shock is the rears.
TurboStangJON
04-27-2012, 12:37 PM
Wrong, it's not a strut in the front. A strut would bolt to the spindle and the car wouldn't have an upper control arm.
