Anyone make an off the shelf, over the axle X pipe set up for Hooker LTs?
Had Mufflex Y on the car, did emissions with the JetHot catted Y which I don't like because it's too quiet & it feels like hurts power. (Need to dyno to find out.) Been thinking about some sort of dual 3 inch over the axle set up with a X pipe. Since the header primaries are 3 inch I sort of hate to neck down. Anything out there off the shelf?
Other suggestions?
Thanks
Other suggestions?
Thanks
I don't know of any prebuilt systems, but it might be tough to get 3" mandrel over the axle. I have never seen that done, or at least posted. There's a theory that says you can run 3" out of the header and through the X, then to 2.5" before and over the axle. The exhaust velocity changes should support most common hp levels at stock displacement and high RPMs.
