Injectors
Injectors
I just had my conputer tuned by pcmforless and they tuned 30 lb injectors but have not received them yet will it be okay to start the car with the stock ones if your computer is tuned for the 30 lbs just so I can check the valves?
FWIW I have 30# SVO and put my stock 24 back in for a "test". No issue. I drove the car a few blocks for the "test" (needed to confirm if one or more of the 30# injector coils were bad)
to just run the motor at idle to adjust valves should not be a issue. Sustained WOT pulls..yes
If you have data loging you can see if the AF mixture is really lean but for me it was not.
