badazz81z28
04-26-2012, 09:49 PM
Going to install a SLP double roller chain, Does this tensioner need to come off for its install and proper operation?
Its an LS1 and I guess its a rare part on the LS1.
Thanks,
CutLS
04-26-2012, 10:02 PM
You shouldn't need to remove it if the chain will not slide past it, but you can. It's only two bolts. I've been looking for that for my LS1 because I installed the SLP double roller timing set and oil pump. I wasn't sure what motor I had when I first got it and bought the Katech LS6 damper which I will end up selling cheap soon. Good luck.
3rdCoastPowerSports
04-26-2012, 11:57 PM
take the damper off, put the the cam gear and timing chain on. then put the damper back on.
