Dyno Guesses & Bench Racing Forum - about what e.t. should my bolt-on z28 run?
2000whitevert
04-27-2012, 12:03 AM
Okay gurus of the ls1tech world i have a 2000 z28 with a small cam (not sure on specs) 3600 stall built trans 3.73s bbk ssi intake bbk 80mm tb bbk fuel rails 30# injectors n pacesetter 1 3/4 lts...either will be on snowflake rims with 295/55/16 bald mickey thompson drag radials or 15x10 racestars with slicks what would be your guys best guess at what the car should run? I will be running the car sunday id kinda like to see how close you guys can come to what ghe car will actually do :)
ds98formula
04-28-2012, 12:03 PM
12.8 @112 make sure to give results. Was it ever dynoed
2000whitevert
04-29-2012, 01:34 AM
Found a dyno sheet in the car said it was makin 300rwhp n 321rwtq
ds98formula
04-29-2012, 09:56 AM
Is this an automatic? It does not sound like the car has any cam in it with thoses numbers. good luck today but i change my guess to 13.3 at 107.
WhiteKnight '01
04-29-2012, 10:11 AM
You have longtubes a cam an 80MM TB and you're only making 300WHP? Get that thing a tune, if all your mods are accurate you should be close to 330WHP with a tune.
With the stall and the drag radials you should at least hit high 12's. What's the DA where you are racing?
WhiteKnight '01
The OP said a 3600 stall.
ds98formula
04-29-2012, 12:36 PM
Totally skipped that when reading. No way that car is camed. I take it previous owner said it was?
2000whitevert
04-29-2012, 10:55 PM
I also have a 11 sec awd tbss i had my dad drive that n i drove the z and the camaro pulled away from tb so its makin some shit. Problem is previous owner bought the car the way it is and the dude is a straight dumbass so what he said n what the car actually has could be way different. And im not sure on da i live in northern indiana
ds98formula
04-30-2012, 07:38 AM
Did you run it yeaterday?
VandykeT/A
04-30-2012, 10:27 PM
My 2000 Z28 M6 (LS1 intake) went 12.8 at 106 with longtubes,ory, lid, and 4.10s on a set of ET Streets. Maybe the dyno sheet was from before the cam? You should be able to hear a little chop even with a baby cam. My guess would be with a good hook high 12s at least but mid 12s should be possible.
2000whitevert
05-02-2012, 12:17 PM
No i drove it to the track and the 28/10.5s were rubbing on my bumper cover so i have to wait til my lcas get here im hopin everything gets here by friday but its not lookin good. And in regards to the dyno sheet i have a hard time believing it only makes 300rwhp but who knows..
ds98formula
05-02-2012, 12:19 PM
Well let us know when you do go
2000whitevert
05-02-2012, 09:13 PM
Will do still no suspension parts so im starting to doubt it will be together by friday
