Forced Induction - Virgin 99 ss looking to hit 500hp Ideas???
jdsuperstreet
04-27-2012, 04:12 PM
hey guys whats going on just pick myself up my first ls1 camaro ive had every other type out there but a ls1..i want to get it to 500Rwhp.."most comfortable power for me" i was thinking of keeping it Sleeper..with a rear mount turbo setup and all the bolt on's...my question is..what bolt on's are good for the ls1...im getting mixed reviews about alot of companys parts..im looking at the texas speed Long tubes with catless y...and possibly a fast intake and im trying to figure out what else...let me know some ideas...thanks guys looking for a good street sleeper build
abeaver
04-27-2012, 07:30 PM
If you want to go with a rear mount, I wouldn't waste money on headers, normally they will hurt your spool time. Alot of sts cars run stock exhaust. If you decide to go the rear mount route, spend your money on fuel upgrades and a new clutch.
TheLS1Lover
04-27-2012, 07:33 PM
Build your own system or STS is an option. I would run a 70mm Turbo and wrap the exhaust all the way back to get some exhaust flowing. Also just run an LS6 intake, Might Mouse has been 8's on one. Its tried and true and doesn't leak.
jdsuperstreet
05-01-2012, 03:35 PM
thanks guys yea im really leaning towards the sts kit...im reading alot of people complaining about there oil pumps...any response to that word? and also you think i should build a kit myself or just spend the $$$$$ for the sts kit..there alot and it seems like a small turbo..70 trim huh?that seems a little better....8's??? on stock motor..or he got cama and stuff..or did i miss understand my bad if i did..i really wana get the most output of this motor its got 120 on the clock now..i was looking at the fast intake your saying just stick with a ls6? what about a ls2 ported??? or still not enuf..what fuel components are good out there for these ls's?
BOBS99SS
05-01-2012, 04:18 PM
Comp oiless turbo, perfect for rear mount, if your going to go rearmount you mise well build it yourself, or buy on off of tech used, they can be had for 1500 and under, but imo you just get a bunch of pipes, look into the huron speed kit/kytp/mod turbo, they make great stuff for front mount, rearmount is ok but alot hate them, i would like to do a rearmount just because of the ease to do one
jdsuperstreet
05-01-2012, 04:44 PM
yea the ease of it is also why i want to do rear mount not to mention sleeper when u open the hood noone around here really knows what there looking at on a camaro everyone is ricer.....so gay i know...so oiless turbo and just piping kit now what about fuel system components injectors..regulator... stuff like that...i wonder how the Egay turbo kit pipes are...mainly for the front mount and pipes...?
ramairetransam
05-01-2012, 04:52 PM
have you thought about a procharger? procharger and some meth should be 450 and then add a cam with ls6 intake and lungtubes you will be at 500 for sure.
jdsuperstreet
05-01-2012, 05:18 PM
thats tru..the only thing like i said is under the hood i dont really wana change the stock look under the hood...but its allways a option if i find a kit for a decent price its possible..the biggest look difference im going for is the intercooler thats as far i want to go...and ill prob hid that behind a billet grill
TheLS1Lover
05-01-2012, 06:04 PM
I mean on the LS6 intake alone. Don't go with an LS2 intake, they can come apart just like the FAST. The LS6 is more than enough.
As far as fuel is concerned go with 60lb Injectors and do this.
http://ls1tech.com/forums/fueling-injection/856954-diy-twin-pumps-quick-cheap.html
HRHohio
05-01-2012, 06:12 PM
Subscribed... Where are you located???
Stay away from headers, use stock manifolds and TSP ORY pipe.
LS6 cam is a good cheap starter cam for turbo application. (Don't forget to replace springs)
LS6 Intake is a good upgrade too, but not absolutely necessary at this time, maybe when you go > 10 psi boost and/or change heads,etc.
On3 Turbo T76 Ball Bearing is a nice entry level unit that will get you up as far as 650 rwhp comfortably, maybe a little more. If you go rear mount, go with the .81 AR instead of the .96 AR.
Definitely invest in a methanol injection system and possibly the intercooler.
Keep us posted on what you decide.
Good Luck!
boostit5.3
05-01-2012, 06:49 PM
i would also go with the ls6 intake, ls6 cam in nice too but since you are goin turbo for a couple hundred bux you could find a nice used turbo cam.
milkplus
05-02-2012, 08:34 AM
You could slide a 408 with ported 243s in there with a TPIS LS6 intake and it would look VERY stock.
IMO, there's no way to make a turbo car look stock. There's always going to be a giant aluminum tube going to the throttle body.
jdsuperstreet
05-02-2012, 01:13 PM
thanks guys this is all great info it really helps alot..all im gonna do now is look into compoents for the turbo kit.. and yea i know the pipe is gona be a dead give away...i hoping the ricers think hmm CAI lol ...i cant wait till i get my 50 post so i can actually start getting stuff off the classifieds lol...any other info you guys may have dont be afraid to say it..im trying to keep it low budget ishhh...and stock ishhh...
Huron Speed
05-02-2012, 01:23 PM
PM incoming. ;)
stangtrader
05-02-2012, 01:49 PM
Here's my take on it.start with either the t70 or t76 from on3 buy a good wastegate and have an exhaust shop Fab up the piping unless you can do it.on the intake I don't think its needed at the moment or a cam for that matter. I think first and foremost you should build the kit first get the car tuned and driving and go from there. You can make 500 rwhp on a bone stock motor with Meth and a good tune. But you can make more with a cam and intake.here's a quick list of what you'll need.
Turbo,wastegate, exhaust fabed, intercooler piping fabed, intercooler, miscellaneous couplers,tbolt clams,bov,injectors,fuel pump,hot wire kit,tune,scavenge pump,lines,gauges,header wrap approximately 4 2"x50' rolls and a bunch of miscellaneous little things. Looks like a lot of stuff and it is but if you research you can do it for cheap ish.my kit itself has about $900 in it.its all the other things that add up fast. Definitely look at zombies and zl1killas threads. There threads will help out a lot.but with that all being said if I was to do it over I'd probly go front mount. I do like my rearmount and I make right around 500-525 rwhp on a stock lq4 but my main complaint is spool. Its decent but not as early as I'd like.
HRHohio
05-02-2012, 10:19 PM
Beautiful shopping list for a budget build. I agree, the cam and intake can wait for a while. Stock cam/intake/heads + turbo will still get him in the 500+ hp range.
I like my rearmount too, and agree that the spool comes in a bit slow on my T76. I emailed back and forth yesterday with On3 about a .81 AR exhaust housing (I currently have the .96 housing). They said they just got a shipment in of just the housings and could sell them alone (without the rest of the turbo) for like $85 + shipping. I may get one and swap housings to see if that helps spool some. Then swap back to the .96 after I go forged bottom.
Again... nice list to get started and into the 500rwhp + range.
boostit5.3
05-03-2012, 09:04 AM
i would also go with the ls6 intake and ls6 cam/springs, the duel intake wally 255's. im going to be running a hx52 on a stock 5.3 and try to make close to 500, front mount though its goin in a 88 chevy pickup
jdsuperstreet
05-03-2012, 09:28 AM
THATS WHAT IVE BEEN LOOKING FOR!! thanks for the list man now that i know its possible to make a cheap build i should have this thing on the road in no time ...whats this on3 your talking about im new to it pm me...thanks for all the info now what about the dual pump setup that mightymouse is doing ? could that work to? what fuel components you running on urs?
stangtrader
05-03-2012, 01:53 PM
Its on3performance. Basically a ebay Turbo that's proving itself. The dual setup is the might mouse one. You could also run a aeromotive 340stealth. I'm using one and its dead quiet. Should support a Tad over 600whp.
TheLS1Lover
05-03-2012, 03:16 PM
You could always put the Lid back on, looks stock that way.
jdsuperstreet
05-07-2012, 10:19 AM
hey guys ive been looking around online to find a turbo and i looked at the numbers you snt me i was wonderign what you thought of this setup and if anything is wrong let me know what you think has to change thanks...
Cold Side:
Compressor Wheel 76mm
.80 a/r
4” Inlet and 2.5” Compressor Outlet
Inducer- 76.71mm
Exducer- 102.36mm
Exhaust Side:
Exhaust Housing T-4 Flanged Divided
Available in 2 A/R sizes - .68 or .81
3.0" Vband outlet
Inducer- 74.5mm
Exducer- 60.56mm
HRHohio
05-07-2012, 10:29 AM
Thought I would share Skinnies sleeper LTD. It has a giant aluminum tube going into the throttle body, but it just looks like a Cold Air Intake to the unsuspecting challenger. LOL.
Here's a link to his build:
http://ls1tech.com/forums/forced-induction/1418133-142mph-junkyard-5-3-a.html
Pic:
http://i31.photobucket.com/albums/c366/skinniesvideos2/Photo0079.jpg
jdsuperstreet
05-11-2012, 07:04 PM
just wondering how everyones turbo setups are going???
stangtrader
05-11-2012, 10:07 PM
Mines working great.have no complaints of my chinese parts and I even tried taking my bone stock lq4 to 17psi. Makes good power and spools alot faster,but I need some #7 plugs. Im blowing out spark on my tr6 gapped at .028”. I need to do valve springs and a cam soon and unleash more power along with #80 injectors. My #60 s are already maxed on pump gas piss
jdsuperstreet
05-14-2012, 11:05 AM
what setup are you running...rearmount or front? if ya dont mind me asking did you build the kit urself or you buy it pre fabbed...im trying to find somone with a good intercooler pipe kit..
