cam recommendation
cam recommendation
I have a 98 camaro m6 stock bottom end.
prc 5,3l heads
ebay lt headers and ory
ls6 intake
ported tb
224/231 578/588 114
What cam do you recomend?
i dont want to rev the **** out of my 98 bottom end.
and i want good power and good street manors.
prc 5,3l heads
ls6 intake
ported tb
224/231 578/588 114
The following users liked this post:
LionPride (09-15-2023)
what rear gear ratio ?how much power do you want to make,the ported heads help alot.maybe a TSP torquer 3,or look at a street sweeper .I like the newer lobe designs of the EPS cams.
What's the ICL of your 224/231 114lsa, and are you looking for lower power band or about the same, also does it matter if the cam sound is more noticeable to you?
What about lift, how much are you willing to go with?
I have a 3:90 gear ratio and yes i would like the loapy sound but i dont want to big of an LSA cause I still want the car to be drivable with minimal cam surge I have the stock ls6 intake and I hear that gives our around 6400rpm so maybe a cam the peaks its power before that? I also hear stock ls1 rod bolts dont like to be pushed past 7
Take a look at the Futral F12-112 (230/230 112lsa). The lift is only .595" so it's nothing radical lift wise. This is as a big as I'd recommend going without really pushing the power band up much at all. This cam will be easily heard with having 6* valve overlap, compared to your current -1* valve overlap, but it's still far from being anything excessive.
Yeah, you could go smaller but you might not notice a $400 improvement in performance.
http://www.futralmotorsports.com/fms....asp?pf=1&pg=5
