Stereo & Electronics - How did you mount your Stealth Box?
TheHeadFL
04-27-2012, 10:51 PM
So I'm currently replacing my Subthump box from 2003 with a new Double D Mods box because it solves my Firebird fitment issues (interfering with T-Tops).
Anyway, this time I want to make sure it stays snug. Are people mounting their boxes in any way? Are you just relying on the trim piece to keep it in place?
My main concern is it not inching out and rubbing the T-Tops.
JrodCamaro
04-28-2012, 11:15 AM
I didn't mount mind in any way, fits in pretty snug and the weight should keep it pretty well in place unless you whip the rear end out pretty hard, that may do it
DSPDave
04-30-2012, 06:37 AM
Before I put the sub in the box I positioned the stealth box and then ran self tapping screws through the bottom of the box into the frame of the car.
z28clark
04-30-2012, 06:41 AM
Mine fit pretty snug in the hole. If your worried about it moving out of place i'm sure some velcro would do the trick and not put any holes from screws.
LE35thSS
04-30-2012, 10:32 PM
my amp rack is holding mine in place. is was snug without it anyway.
TheHeadFL
04-30-2012, 11:44 PM
I did that the first time I installed my original subthump box, but I decided against it this time because it was terribly difficult to install the sub in the box with it sideways like that.
I ended up just leaving it in there snug against the hatch lid with the rear divider installed to keep the trim in place.
After I finish my body work I may figure out how to mount it better. I'm hoping to find a way that will let me install the sub in the box out of the car first.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
