onequiklx
04-28-2012, 01:04 AM
posted in the conversion / hybrid section and didnt have any luck. Just trying to get an idea what this think should make. this is a repost of what i put there.
In the process of putting an Ls1 in my 90 lx hatch. I picked up a stock 99 ls1 with arp bolts dirt cheap. Motor is ready to assemble. Ill run thru a quick rundown of all the parts. Just curious to what kind of power this thing "should" make. I know lots of variables factor, but trying to get a rough idea.
99 shortblock 60k miles w pistons notched
241 heads ported and polished
Lunati .650 springs, lightweight steel retainers, hardened locks.
217 cc intake runners / 81 cc exhaust ports 61 cc chambers
Flowed on a 3.9 in bore @ 28
IN. EX.
.100 69 53
.200 159 122
.300 201 155
.400 228 176
.500 262 201
.600 288 221
.650 297 226
.700 303 228
Trex V.2 .610 .615 242 248 @ .050 110+2 centerline on a 110 lsa
w 7.350 pushrods
10.9 compression
victor jr carb intake
750 hp holley
msd 6010
kooks 1 7/8s Headers
full 3 in exhaust with x pipe and 3 in tail pipes.
Tremec 3550 with spec stage 3+ clutch, Aluminum Flywheel
4.10 gear in 8.8.
will also be putting a nitrous plate kit of some sort on it also. with 150-200 on it. Just curious what kind of power i should expect on motor and spray. Car should be about 2900 or so with no driver. full tubular front and rear suspension. Thanks for any help in advance. This car has been sitting for 7 years cause of it kept busting pistons on the last combo. and wanting to try something different. Im thinking it should run high 6's / 10s on motor. not sure on spray....
IN. EX.
.100 69 53
.200 159 122
.300 201 155
.400 228 176
.500 262 201
.600 288 221
.650 297 226
.700 303 228
w 7.350 pushrods
10.9 compression
750 hp holley
msd 6010
4.10 gear in 8.8.
