Generation III Internal Engine - Help
camarovon
04-29-2012, 01:38 AM
I installed a torquer v2 cam and now I got valvetrain noise what could it be
justin455
04-29-2012, 02:21 AM
http://ls1tech.com/forums/generation-iii-internal-engine-5/
crainholio
04-29-2012, 02:24 PM
What pushrod length did you use, did you torque the rockers in GM sequence or just run 'em down, how much lifter preload did you get from your measurement, etc etc etc...
camarovon
04-29-2012, 06:46 PM
I know that I got the correct push rod length,but could u please explain the correct way to adjust rockers
camarovon
04-29-2012, 06:49 PM
I got 799 ported heads,they are not milled so texas speed told me to get a7.4 pushrod
crainholio
04-29-2012, 06:52 PM
It's worth clarifying that I didn't say adjust, I said torque. The GM procedure has you tightening each rocker when the lifter is on the cam's base circle, not on a lobe...this prevents excessive loading of the lifter and potentially damaging the piston and/or spring.
What was your zero-lash pushrod length measurement?
camarovon
04-29-2012, 06:58 PM
I never checked with a checker
camarovon
04-29-2012, 06:59 PM
I just used what they told me
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
