Gen 5 Camaro Drivetrain Tech - Gforce1320 Fab IRS 9" Install
View Full Version : Gforce1320 Fab IRS 9" Install
Gforce Engineering
04-29-2012, 12:00 PM
We installed one of our fabricated 9" IRS rear ends in a local customer’s car a few days ago.
Brad (Tornado SS) was starting to get some gear noise from his rear and decided to replace the entire rear drivetrain with Gforce Engineering parts.
He has some pretty big plans down the road and wanted the strongest rear so he wouldn’t have to worry about it later.
We talked with him about his goals which were streetable manners, the ability to go on road trips and the occasional track thrashing and he also wanted something that would be plenty strong enough to later handle a supercharged engine.
We ordered up a Strange Engineering pre-built Pro Iron pumpkin with 4.11 gears and a Strange S-Trac 35 spline posi.
We also went with a Dyno-Tech 3.5" Aluminum slip style driveshaft for super smooth highway driving.
Once everything came in and got built we got to installing everything.
We actually installed 2 9" kits this day and both in Orange Camaro!
The other one we took the 9" kit out and did a big bearing up-grade and installed a new set of 3.70 gears.
Not bad, 2 9" kit installs in one day.
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/DSC00305.jpg
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/81ba14b8.jpg
Our 9" kit bolts in so easily that anyone with a lift can do one in half a day with nothing more then regular tools.
First up was getting the cat back and stock driveshaft down and out of the way.
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/DSC00302.jpg
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/DSC00279.jpg
Here is the stock driveshaft compared to the new Dyno-Tech 3.5" aluminum shaft.
The stocker weighs 24 lbs and the Dyno-Tech shaft weighs 15 lbs for a 9 lb weight savings.
You will notice the Dyno-Tech shaft does not use any rubber couplers or a cv joint on the front.
It has an internal slip shaft assembly that allows it to move in and out with the suspension travel, this type of shaft provides a very smooth and vibration free ride with our 9" kits.
We can also do this shaft in a 4".
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/DSC00290.jpg
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/DSC00277.jpg
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/3c2fa8ba.jpg
And now out with the stock center section and axles. Now we can bolt all the new components in.
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/c13acc5c.jpg
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/DSC00275.jpg
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/486887ff.jpg
The new axles and assembled center section ready to bolt in.
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/3e4c6a90.jpg
We start by installing the new outer stubs and then the axles, once they are installed you can raise the center section up in place and bolt the axles to the inner stubs.
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/d6aaf6c1.jpg
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/DSC00285.jpg
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/DSC00284.jpg
You simply raise the center section up into the OEM mounting locations just like you would the factory rear.
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/DSC00287.jpg
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/DSC00286.jpg
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/DSC00298.jpg
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/DSC00291.jpg
Our 9" housing comes with a fill bung so you can easily fill it with lube after install.
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/DSC00296.jpg
Next up is installing the driveshaft.
You bolt the supplied front adapter on first.
You need to push the heat shield up a bit but the driveshaft will bolt right in with all the factory heat shields in place.
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/DSC00293.jpg
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/DSC00294.jpg
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/DSC00297.jpg
Next up is hanging the cat back up.
Brad had a Borla cat back and it fit perfect with the 9"!
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/DSC00299.jpg
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/DSC00300.jpg
Back on the ground all done in under 3.5 hours :headbang:
http://i25.photobucket.com/albums/c91/nicholscl/Tornado_SS_9in/18c8e7dd.jpg
Gunslinger09
04-29-2012, 02:05 PM
Wish I had the $$$ for this set up.
silver2010
06-10-2012, 02:23 PM
Mine's on order,hee-hee! Can't wait to get this badboy in so I can beat the hell out of it.
GFORCE1320
08-20-2012, 06:48 PM
Keep us posted on your build, I'm looking forward to seeing it hit the track!
Stangkilr
11-16-2012, 05:58 PM
Such a nice setup I just dont want to spend that for a rear end...ill go solid axle for that.
Gforce Engineering
12-07-2012, 09:54 PM
Glad we convinced you to go with the Gforce 9".
I'm looking forward to the install :)
Thanks
Chris
