Generation IV Internal Engine - New heads for T Rex cam
View Full Version : New heads for T Rex cam
19BLACKBIRD99
04-29-2012, 12:53 PM
Im looking for some idea or recommendations on heads for my T-Rex cam, I have patriot stage 3 ls6 heads, lookin for a new combo to get some more power out of it.
mikh338
05-06-2012, 11:14 AM
what power are you making on this setup? i cant wait to do heads with the trex. i was leaning towards the ls3 heads
87silverbullet
05-06-2012, 12:48 PM
Since you already have ls6 heads, I would look into some aftermarket heads like AFR's or Trickflows.
The Trex wasn't really designed for LS3 heads. It will make power but it will make better power with a cam designed for rectangular port heads. Check into EPS cams. Geoff is the shop owner and he was co-owner of Thunder Racing and he is the guy who devolped the Trex when he was at Thunder. He just recommended a cam for bmw5388 on here that is 230/242 for his 370.
mikh338
05-06-2012, 01:25 PM
yeah i was acutally speaking with bmw5388 thru PMs and he has been helping me out also. I am not looking to change out the cam so it will have to be heads that work well with the Trex, I will contact Geoff, thanks!!
87silverbullet
05-06-2012, 01:38 PM
Well you fall in the same boat then as far as heads since you don't want to change the cam. I would look into some TFS 215's
mikh338
05-06-2012, 01:43 PM
yeah i bought the car setup as it is, and if i can find a good set of heads to match the trex i will. i dont want to have to change the cam out etc. i love this cam it screams and sounds nasty. i will look into the TFS 215s
mikh338
05-06-2012, 01:44 PM
now that i think of it, i think someone else mentioned to me the tfs 215s or 225s before also
87silverbullet
05-06-2012, 02:15 PM
Get the 215's if you don't plan on upgrading for quite a while. The 225's might make your 370 a little lazy on the bottom end since you have a 6 speed. if you plan on going bigger later get the 225
mikh338
05-06-2012, 02:23 PM
thats another good point, i have not decided yet but over winter i may pull it and go 400+c.i.
19BLACKBIRD99
05-06-2012, 11:17 PM
The guy from texas speed told me prc 227? Or something like that I forgot!
87silverbullet
05-07-2012, 07:13 AM
I don't see how. That head is for a 4 inch or larger bore. You still have an LS1 right?
19BLACKBIRD99
05-07-2012, 12:50 PM
Yup, and needing heads for the right bore is why I'm here lol because the ls6 heads are the same problem for me
87silverbullet
05-07-2012, 03:58 PM
AFR 205's or Trickflow 215's would be your best bet for a stock cube ls1. The only other thing I might try is a set of Advanced Induction LS6 heads. Their porting program has produced some bad ass results from a stock casting head.
NemeSS
05-07-2012, 04:36 PM
pm me if you decide to sell that trex:cool:
