eb110americana
04-29-2012, 04:21 PM
I'm trying to diagnose a several month old intermittent (mild, but usually present) hard start condition and poor gas mileage. I've already done:
Fuel filter
Air filter
PCV Valve
PCV hoses
Sea Foam gas tank
Power Foam intake (removing oil from bad PCV)
All O2 sensors
Cleaned MAF
IAC replaced
Currently, I'm checking the fuel pressure and it goes to a tick over 60 PSI when priming and when running. I have '98, so keep in mind that the fuel system is a bit different from '99-'02 cars. I've read on some pages that it is a return-style system, unlike the later models, but I'd always thought it was returnless. When priming, the pressure goes to ~61 and then almost instantly begins to fall back to zero which takes another few seconds. When using the bleed-off valve in the test gauge for a clean disconnect, no fuel even comes out.
I pulled the rail and left all the injectors on and primed it looking for leaks. I couldn't find a single one. Tried with and without the harness attached. For now I am soaking the fuel injectors in Sea Foam as long as they are out of the car.
Could this mean a bad fuel pressure regulator? Is this behavior normal? What else should I check for? (For the record, I don't recall having a fuel cutoff at the top end.)
Fuel filter
Air filter
PCV Valve
PCV hoses
Sea Foam gas tank
All O2 sensors
Cleaned MAF
IAC replaced
