Manual Transmission - GTO t56 work on a 6.0l
68BBChevelle
04-29-2012, 05:56 PM
Hey guys im in the market for a t56 for my chevelle, ive been trying to find one out of a fbody but no such luck. I was wondering if a GTO t56 will work? Whats the difference between it and the Fbody trans. Thanks for the help.
thesource
04-29-2012, 06:22 PM
There are quite a bit of differences between the F body and GTO but since they are packaged in basically identical configurations, they actually interchange with each other. All you need to do is make sure the shift select lever from an F body is installed in the GTO unit and it will work just fine.
Nmbr1GMfan
04-29-2012, 09:20 PM
GTO=2.97 first Fbod=2.66 first
lo&sloSierra
04-29-2012, 10:30 PM
The starter spot in the gto bellhousing is smaller, get a gto starter to go with it.
68BBChevelle
04-30-2012, 12:05 PM
would the camaro bell work or do it have to use the gto. I just put on a brand new truck starter.
lo&sloSierra
04-30-2012, 12:46 PM
I cant remember if the bellhousing swaps.
GTO trans + Camaro bell + truck starter works.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
