Stereo & Electronics - Big 3 Upgrade
View Full Version : Big 3 Upgrade
youcancallme29
04-30-2012, 10:16 AM
Looking to build the wires for the big 3 upgrade myself, but I have a couple questions first. Where can I get the 0/1 gauge wire without it costing me a fortune? Does anyone have any pictures of the end of the cables where they attach to the battery so I can see how they are soldered. And what cable ends do I use? Thanks.
sjsingle1
04-30-2012, 12:39 PM
http://ls1tech.com/forums/generation-iii-external-engine/1439464-alternator.html
Earnhardt
04-30-2012, 01:30 PM
I'm not sure how much you think a "fortune" is, but KnuKonceptz has 1/0 gauge wiring for $3.95/ft.
http://www.knukonceptz.com/productMaster.cfm?category=Kolossus%20Fleks%20Kabl e
Or, if you don't need pure copper, $1.95/ft.
http://www.knukonceptz.com/productMaster.cfm?category=KCA%20Kable
Daniel Richards
04-30-2012, 08:32 PM
Thats the wire I used, the 3.95/ft stuff, plus I have an optima redtop, so I bought there top post pair for like 40 bucks so I didn't have to add a bunch to the side posts I spent about 80 bucks with shipping between the battery post pair and 2 packs (4 connectors total) of ring terminals, and the like 6 or 7 feet of cable I needed since my V6 has the alternator right on top there.
TheHeadFL
04-30-2012, 11:49 PM
I bought a battery cable set from Innovative Wiring Concepts last year ($85) and I was very happy with the quality.
My personal opinion is that I could've maybe done it for a bit less money myself, but my time is worth something, and working with that thickness of cable is VERY difficult. Even just installing it in the car. I was glad they had a ready made product that worked great.
youcancallme29
05-01-2012, 08:58 PM
Yeah I saw your pictures you had posted. The cables look great. Its more like what I am looking to do is replace the cables. It seems like alot of the guys on here that do it themselves just run an additional cable along with the stock cable which is just more clutter in my opinion. Do you have any pictures of the cables installed? Id really appreciate seeing them if you did and dont mind. How well did everything work? Do you know what his gaurantee on the product is?
TheHeadFL
05-01-2012, 10:14 PM
I can go take a few pictures tomorrow.
In short, they fit very well with the caveat that heavy gauge wire doesn't like to bend or twist easily. So the lug connectors are a bit challenging to connect to the starter and alternator posts, for instance. It requires being a bit creative with where and how you bend the cables.
I don't know what the guarantee was or is. I've had them for I guess nearly a year now (although I don't daily drive the car) and they still look like new. I'm really not worried about them, they're very substantial.
Daniel Richards
05-01-2012, 11:37 PM
When I MADE my cables I replaced the battery negative to chassis ground and the alternator to positive battery, but I doubled up the battery negative to engine block and the battery positive to fuse block simply because there was no reason to remove them.
youcancallme29
05-02-2012, 01:19 PM
Thanks theheadfl I appreciate your help. In going to wait to see your pictures before I order them.
slomarao
05-02-2012, 01:43 PM
http://www.camarozone.com/big-three-upgrade/
youcancallme29
05-02-2012, 03:08 PM
Thanks for that link, I dont understand how the end for the battery gets soldered with an eyelet connector with three 0 gauge wires going into it
TheHeadFL
05-03-2012, 10:20 AM
Didn't get a chance to get under the car to photograph the ground wire and starter wire, but here is the wires connected to my battery and alternator.
(Please excuse the smaller red wires, those are related to my battery maintainer and electric water pump)
youcancallme29
05-11-2012, 12:05 PM
Thanks for the pictures. I appreciate it. So the wiring kit replaces the factory wires not just adds to them right? Just trying to make sure I know what I am getting. Does it go to the fuse block to?
TheHeadFL
05-11-2012, 12:54 PM
It replaces the entire factory battery harness, yeah.
It does not go to the fuse block.
Off the top of my head it goes:
Battery Negative to:
- Chassis ground
- Engine block
Battery Positive to:
- Positive distribution block
- Starter
- Alternator
youcancallme29
05-14-2012, 08:14 AM
- Chassis ground
- Engine block
- Starter
- Alternator
Thanks again. I ordered my kit on friday hopefully it will be here this week. :cool:
joblo1978
05-14-2012, 09:03 AM
I got about 10 ft. of leftover 1/0 kicker with some terminal ends I'll see you. I suppose I could ship it for 60 bucks. Shoot me a pm.
youcancallme29
05-14-2012, 11:25 AM
Thanks, but I just bought the wiring kit, just much more cost effective in my opinion plus it replaces the entire factory harness so I think ill be much happier that way. Thanks again.
