surferstick
04-30-2012, 10:38 AM
Hey Guys. I'm new here, but not the least bit new to cars or modding. The latest add to the toy car fleet is a 98 Trans Am convertible with only 65K miles on it.
Of course it has the orange needles like every stocker has. And since my car is all black with red accents, I wanted red needles. I didn't want to do the Camaro red needle swap though, I wanted something a little different. My winter beater is a 05 Grand Prix, and I like the shape of those needles, so I bought two junked clusters and did this conversion for the TA. A GP cluster has a short tach needle, so toss those, and you'll need 2 speedo needles, and 4 small instrument needles. All needles need a bit of trimming, as the GP ones are slightly longer as you can see in the pics. As you can see in my last pic, when the car was shut off, the needle wouldn't fully drop to 0. This is because the GP needle has a copper counterweight in the stubby end, and after I trimmed the long end, I guess it became a bit tail heavy. Anyways, I carefully drilled into the counterweight to remove a bit of material, and now they drop to 0 like they should. I also included a pic of the backside of the short needles, showing a little plastic stop you will need to cut away on the GP needle to make it fit. Oh, and the GP speedo needle has a longer shaft (no giggling), where it fits into the stepper motor on the cluster, so you will need to cut that shorter, then drill it out with a super tiny drill bit (sorry, I didn't note the size)
