New LS1 Owners - Newbie Tech - mid tubes vs long tubes
jpbluebird
04-30-2012, 11:55 AM
I have a 99 firebird formula and it already came with Mac mib tube headers, I was thinking of getting a set of pacesetter long tube headers......do yall think there would be much of a hp gain?
jpbluebird
04-30-2012, 12:09 PM
That's what I was thinking.....and I've heard they aren't very easy to install.
ULTIMATEORANGESS
04-30-2012, 12:18 PM
its worth upgrading imo.
1lejohn
04-30-2012, 12:21 PM
you'll gain torque with the long tubes. They should make about the same peak HP. If you keep out of the gas the long tubes should increase your fuel milage.
The Macs are ok if they are in good shape. I ran them years ago. I did find that the long tube Pace setters were easier to install. They did give better clearence in the engine compartment over the Macs.
RPM WS6
04-30-2012, 12:59 PM
Agreed, epecially if it's just a bolt-on car.
jpbluebird
05-01-2012, 12:27 AM
It is a bolt on car for now, but I have an ls6 intake, 243 heads, 42lb injectors, and a 2500 stall in the garage ready to be put on. I'm just trying to figure out what cam I want to run. I was thinking the tr224 would be perfect.
ULTIMATEORANGESS
05-01-2012, 06:14 AM
sell that 2500 stall for something higher.
RPM WS6
05-01-2012, 12:50 PM
:nod:
2500 is about 1000rpm too low for even a stock LS1. If you plan on a cam as well, 3500 would be the absolute minimum IMO.
wooddaniel
05-01-2012, 01:59 PM
:nod:
+1, At least a 3600; it will wake the car up. You wont notice anything under 3000
1lejohn
05-01-2012, 05:34 PM
It should be a nice build. Like posted above a bigger stall for the track but with a 224 cam you could stay with a near stock one and make a nice DD. It will put down some good dyno #'s esp. with stock gears. I would say in the 400hp range.
A bigger stall, gears ?? and good tires would make it a strip hero. Then the parts breakage begins. LOL
RPM WS6
05-01-2012, 09:40 PM
Even for a daily driver I'd want a lot more stall for that cam, or any cam. Stock shift extension isn't even close to ideal for a stock cam, let alone something bigger. Idle tuning will also be more difficult with a stock/stockish stall and a 224 cam.
T3X_SS
05-02-2012, 01:05 PM
Agreed ^^^ with the guys above, i noticed a big difference when i installed my Vig 3600 on a bolt on car
T3X_SS
05-02-2012, 01:07 PM
Planning on doing H/C next month
