Pontiac Firebird 1967-2002 - Little black box
lakeratiam
04-30-2012, 03:27 PM
Anyone out there have any idea what the little black box about 1=1/2" sq. under the dash mounted up and to the left of the clutch pedal with a 14 or 12 ga.yellow and a brown wire is? Looks like some sort of relay possibly. Wish I could describe it better. Only has the two wires plugged into it.:confused:
Nathan C
05-01-2012, 12:54 PM
Pictures? Could it be aftermarket?
lakeratiam
05-01-2012, 11:07 PM
This is the best pic I could get, pretty cramped there. Is it the safety/neutral switch? It was jumpered, I took out the jumper and plugged the harness back in, now the car won't start.:mad:
http://i1094.photobucket.com/albums/i455/lakeratiam/2-3.jpg
JohnnyBs98WS6Rag
05-15-2012, 11:36 AM
It sounds like it might be your clutch safety switch. I'm betting it was jumpered-out because it went bad and didn't allow the engine to crank. Now that you've reconnected it, the original problem returned (engine won't crank unless this switch is closed by depressing the clutch pedal).
Paul Bell
05-15-2012, 08:59 PM
You'll need to tell us more info about the car. Year? Auto or stick?
They made a lot of Firebirds starting in the sixties...
SVTconfused
05-15-2012, 09:02 PM
buy here pay here car at one time?
great421
05-16-2012, 01:16 AM
See the GM Service Manual -
Page 8A-30-0 Yel / Brn = Clutch Pedal Position (CPP) switch (aka - "Clutch Start Switch" in GM-speak).
Do NOT get a non-GM replacement - they are total junk. I busted three in three days; paid the 15% extra, got a real GM unit, issue resolved.
So, the reason the car will not start is that your VATS system needs power on that Brn wire to trip the Anti-Theft Relay.
Jumper that 2-Pin conector untill you get a new CPP switch.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
