mrath
04-30-2012, 03:50 PM
Car: 2000 trans am ws6 6-speed.
Problem:
I started the car in neutral and was not able to get into a gear with the clutch pushed in. I turned off the car, put it in gear and turned the car on. It seemed to recognize the clutch being pushed in because it didn't lunge forward and I was able to drive home alternating b/t gears but I did not put it in neutral when I came to a full stop. I haven't use it since then but my guess is something is beginning to go out. I'm not as knowledgable about transmissions so I don't know if this could be a problem with flywheel, throw out bearing or clutch cylinder. I checked fluids levels and they seem to be normal. Any suggestions on what the problem may be?
Problem:
