Drag Racing Tech - Best way to remove spray underliner
INTENESS
04-30-2012, 04:00 PM
I wont to get the spray under liner from the rear wheel wells,whats the best way to get this tar looking stuff off?
JL ws-6
04-30-2012, 05:58 PM
Heat gun and a putty knife, may need to actually put a torch to it a little to get it heated up good. It's a pita but it will come off.
EDS01SS
04-30-2012, 06:50 PM
i used spray can paint stripper, putty knife and a small rubber mallet to get mine removed
Nsty98LS1
04-30-2012, 08:44 PM
a good heat gun & a scraper. then some kerosene to wipe some of the residue away.
68 SS
05-05-2012, 03:15 PM
60 grit flap wheel on an angle head grinder will bring it right off.
tektrans
05-05-2012, 04:46 PM
Yeah but thats a 9sec car he's got and I am sure there is a whole lotta tire rubber in those fenderwells covering the paint, which will just gum up that flap wheel. ;)
JL ws-6
05-05-2012, 10:08 PM
There's probably 10+ sets of tire in there!
INTENESS
05-06-2012, 03:25 PM
Thanx for the helpful ideas,I did remove the rubber I had jus about 10 pounds of rubber in the wheel wells it was over 3/4"thick.,Im trying to get weight out the car so rubber has to go lol
BlackScreaminMachine
05-07-2012, 08:00 AM
Jesh, 10 pounds, that up there with taking a crap before you race!!
studderin
05-07-2012, 03:13 PM
every spot if different on the car. It kinda depends if you want to fling hot melted shit all over, but easier with a power tool doing the work. Or musceling it off in a big sheet/spot with a sharp/hot putty knife, and beat the shit out of your hands (slips off), and sweating you ass off.
I used everything, Wire wheel, scotch bright wheel, flap wheel. All work.
And the heat gun, a torch, stiff metal putty knifes work too. Depends if its Just the under coating and a flat spot, curve, hard to reach spot. or the seam sealer foam stuff under it too. I dont think there any one way thats best, just whatever for you works.
JL ws-6
05-07-2012, 04:12 PM
It's going to be messy, that much count on
ctjohns
05-07-2012, 08:15 PM
Getting in the mood to start this on mine........may just have another crown an coke.......and do some more bench racing!!!!
JL ws-6
05-07-2012, 08:54 PM
Couple more of those and you will be really ready to get started.... wear safety goggles if you can still see strait enough to work :chug: :jest:
ctjohns
05-08-2012, 06:40 AM
lmao, no doubt
