Carbureted LSX forum - What fuel setup?
View Full Version : What fuel setup?
ntxf
04-30-2012, 04:02 PM
Im getting ready to start swapping my 2003 mustang gt to a carbed,sprayed lsx. I have my list of parts for the swap,minus the fuel system. I eventually am going fuel injected, so if there is a setup that would work for both, that would be good. if not, what pump and accessories should I use for the carb setup? Do I need a sumped tank? And is yhereany intank pump that will work?
Thanks in advance
ZONES89RS
04-30-2012, 04:51 PM
Stock in tank pump will work with a high pressure bypass fuel pressure regulator.
